Problems while turning.
Old Feb 4, 2009 | 05:52 AM
[roger]'s Avatar
[roger]
Exclamation Problems while turning.
So I was driving my dodge and then i notice when i turn at a stop light or a running stop, my truck would stuggle while turn the wheels while in the turn but then it goes back to normal when i straighten the wheels.
this driving me crazy, It kinda make not want drive my truck because am afraid of causing harm.
also why does my truck does not cherp when i lock the doors anymore?
well thank you for your time,
Old Feb 4, 2009 | 07:05 AM
punkrguy's Avatar
punkrguy
Have you checked your power steering fluid lately? Is there any noise associated with the hard turning, such as a kind of a howling sound?
Old Feb 4, 2009 | 08:40 AM
olyelr's Avatar
olyelr
Kind of a dumb question, but is the truck in 4 wheel drive?
The chirping thing when you lock the doors is optional. My truck did it when I first got it and it bothered the crap outa me. So then I programmed it so it would not honk the horn every time it was locked (but I cant remember how, I believe I looked it up in the owners manual). Maybe you accidentally pushed the code to make it not honk?
Old Feb 4, 2009 | 09:30 AM
[roger]'s Avatar
[roger]
no it 2x4, 5.9
yeah, i checked it and it was fine.
Old Feb 4, 2009 | 10:01 AM
shawngrace5's Avatar
shawngrace5
I would look toward something in front suspension. Check your wheel bearings, ball joints, bad tie rods maybe? Seems like something is putting the steering in a bind.
Old Feb 4, 2009 | 11:27 AM
[roger]'s Avatar
[roger]
well i did change my ball joints but like 2yrs ago
Old Feb 4, 2009 | 12:01 PM
PressB's Avatar
PressB
by struggle, do you mean the engine would struggle? or is it hard to turn the steering wheel when you're not moving? or does it feel like your front brakes are on when you're turning?
If the engine is struggleing, you might have a locked up rear diff that isn't allowing the rear tires to move at different speeds and putting a load on the tranny.
If it's hard to turn you're looking at a number of things it can be from wheel bearings to brake calipers to steering components.
If it feels like your front brakes are on in the turn, you might have a pinched brake line that whenever you turn the wheels with the brakes on it locks the pressure until you turn it straight again.
Hope this helps with the hunt.
Old Feb 4, 2009 | 01:38 PM
[roger]'s Avatar
[roger]
I know that not the my powersteering, it struggles to accelerate properly while turning. for example it like if you have a std transmission and you are letting it go of the clutch to fast and what does it do? it stuggles. the motion is like that. except my truck is automatic. btw how can you tell your diff is lockin up?
Old Feb 4, 2009 | 01:49 PM
xskylinedx's Avatar
xskylinedx
Stop me if I'm being stupid; Could he simply have a bad serpentine belt? The turning puts
extra load because of the power steering pump and since the belt is bad it slips more?
I know thats kinda out in left field but I thought I'd throw it out there.
Do you get any creaking? groaning? Have you checked your steering stabilizer? I had a
bent stabilizer from an off road incident and it really mucked up my steering capability.
Old Feb 4, 2009 | 01:57 PM
[roger]'s Avatar
[roger]
it cant be my belt since it still good, well that what my cousin told me when i changed my belt tensioner. and no i have not been offroading in my truck i wish i can but i dont since it 2X4
