throttle valve (tv) replace?
Old Feb 5, 2009 | 11:46 PM
a320drivr's Avatar
a320drivr
Default throttle valve (tv) replace?
Thanks in advance:
My first dodge 1500 quad 4x4 5.2l...1999 with 106,000
My TV cable is broken at the throttle body. The plastic attatchment piece broke as i tried to remove it in order to clean the IAC.
I called the dealer and he wants 75 for a cable, however all the truck yards tell me they have dodges with 5.9l and to 'come take a look'.
Is it worth the effort to try and find an exact cable at a yard? Does is need to be the exact 5.2 year, make and model?
How difficult is the cable to replace? I looked under at the tansmission and already it looked like a pain....
Old Feb 6, 2009 | 12:21 AM
dakotas ram's Avatar
dakotas ram
not positive but they should all be the same at least on the tb side, not too sure about the transmission end......i changed one out on a camaro with a 700r4 and it was only a pain b/c of ground clearance on your truck it shouldnt be too bad.....i would wait for others to chime in on if theyre the same or not....for that camaro there were 2 dif lengths for the dif trannies
