1996 46re trans rebuild
Old Feb 7, 2009 | 06:37 PM
scot2hot's Avatar
scot2hot
Thumbs up 1996 46re trans rebuild
would like to know what kit to buy for my 1996 ram 5.2 4x4 ,the trans is a 46re(gave dealer vin number,they told me it was 46re)where to buy kit and recommendations on what else to replace.also is my trans a 518?thanks Scott
Old Feb 7, 2009 | 07:30 PM
gobbell1's Avatar
gobbell1
Are you sure you need a rebuild?
What symptoms are you experiencing?
Old Feb 7, 2009 | 09:06 PM
scot2hot's Avatar
scot2hot
Default 1996 ram
truck wont move in any gear,found part of snap ring in pan
Old Feb 7, 2009 | 10:50 PM
dblj16380's Avatar
dblj16380
Wink
This snap ring you found may just be one from the oil pump on near the "bell housing" part of the trans. It still has to be dropped to check it though.
However, if you do want to do a rebuild then there are a few different brand kits out there that you can buy. MonteC would be the best to consult on this one. He is a trans tech.
While it is out though, I would definently install a shift kit. I know that MonteC and others recommend Sonnex brand parts. I just went the cheap/easy way and put in a Transgo TFOD JR shift kit. It was only about $20 and it wasn't very difficult to install. It isn't the best out there, it will just give you a slightly firmer shift. Transgo also makes the HD-2 kit that is much more heavy duty.
Old Feb 8, 2009 | 11:24 AM
scot2hot's Avatar
scot2hot
Default ram trans
thanks maybe montec will read this and give me some advice
Old Feb 8, 2009 | 05:40 PM
scot2hot's Avatar
scot2hot
Default 1996 ram tranny
anyone got something
Old Feb 9, 2009 | 05:53 PM
scot2hot's Avatar
scot2hot
anyone with some advice on what to get and where
Old Feb 10, 2009 | 01:41 PM
MonteC's Avatar
MonteC
I think master tech replied to your other thread. That snap ring is for the Overdrive Direct Clutch. Very common.
I would recommend using a sonnax sure cure kit when rebuilding. The basic stuff you are going to need is an overhaul kit (paper/rubber). Clutch kit. And mostly likely some bushings. And of course a new snap ring.
I dont know if im supposed to say this or not but i work for/with a transmission parts store.
You could also try Wittrans.com
