Both Headlights stop Working
Old Feb 8, 2009 | 03:55 PM
specialist484's Avatar
specialist484
Default Both Headlights stop Working
Hello,
I have a 2001 Dodge 5.9 4X4. I live in Alaska, so it does get real cold at night and that might have to do with the problem. A couple of days ago both my headlamps went out. All other lights work (ie. blinker, side lamps and fog lights). I checked both the power distribution center (under hood) and the junction box in the cab for open fuses, but didn't find anything. What else could be causing this? I checked the bulbs and both are good. I also checked the wiring diagrams. I know its probably a simple fix-can anyone give me their opinion? Thanks.
Old Feb 8, 2009 | 04:20 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Take the headlight switch out and see if the harness or the switch itself has a melted pin.
Old Feb 8, 2009 | 04:52 PM
specialist484
yeah, I know that is going to be the best way to troubleshoot, but I don't want to take it out if its not the problem( -2F). My high beams work, just no low beams. Thats what I will do soon. Any other suggestions?
Old Feb 8, 2009 | 04:54 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
If you haven't done so, check for voltage at the headlight receptacles. No voltage = blown fuse, bad HL switch, or bad ground. I believe the HL ground on a 2001 is up under the dash behind the cup holders.
Old Feb 8, 2009 | 05:04 PM
Rex-TheDOGG
Sounds like you've narrowed it down to the HL switch or HB switch. Just pull out the HL switch far enough to TS. I believe the HB switch feeds into the HL switch.
Old Feb 8, 2009 | 05:19 PM
zman17's Avatar
zman17
It's rather easy to take the headlight switch out.
