Vacuum leak
Old 03-23-2009, 10:08 PM
2damnyankee's Avatar
2damnyankee
2damnyankee is offline
Originally Posted by 97TClxiSTL
Obviously I have something wrong here. No idea what I'm missing. The screw shouldn't be there I know that, but I can't seem to find a vacuum hose that isn't connected so I dont know what should be connected here.
Of couse this is what I am guessing is causing my wild vents when accelerating.
Anyone have pictures of what should go here? The problem is circled in red. Other picture is identical just not marked where the screw is.
This is on a 97 club cab 5.2 4x4.
Thanks!
Now i just went out to check my 95 and the check valve that has the screw in it had a little hose that goes into the cab and the one that looks like it is running into your cab runs down the back of the motor for the transfer case. now mine is a 2500 might be different, but they could be backwards if someone had it before you.
Quick Reply: Vacuum leak
