Missfire codes but no mis fire
Old Mar 12, 2009 | 09:02 PM
  #21
dodgeboy7's Avatar
dodgeboy7
so i clean the cam sen and the light came back and then i replace with a new one and the light came back so now what
Old Mar 13, 2009 | 02:58 AM
  #22
macanddons7's Avatar
macanddons7
do a compression test when the engine is hot , check the two center holes first then do front then back hole write it down. Drive it for a while then do it again the diff will only be a couple of pounds. If so you've cracked a head or gasket .have them fluxed if thats the prob order new head. when long block was assembled they couldn't see the crack and prob dismissed it.
Old Mar 13, 2009 | 03:02 AM
  #23
macanddons7
Post been there done that
the time you spent trying to figure it out is info for every one else.]do a compression test when the engine is hot , check the two center holes first then do front then back hole write it down. Drive it for a while then do it again the diff will only be a couple of pounds. If so you've cracked a head or gasket .have them fluxed if thats the prob order new head. when long block was assembled they couldn't see the crack and prob dismissed it.[/quote]
