Missfire codes but no mis fire
Old Feb 9, 2009 | 12:28 PM
dodgeboy7's Avatar
dodgeboy7
Default Missfire codes but no mis fire
once about a week i get miss fire code in every cycinder and the multiup miss fire. It usally then pulling hills or when i get in to it a bet. But i cant feel a miss fire it runs like a rap date. Now rember i have a rebuilt longblock i had built for my truck(put the rod though the side the motor). When i put the motor in i put new cap, rotor, plug (stock autolites) and wires. The motor only has about 3,000 miles on it so far. I might trying change the plug with diff autolite the colder one or w/e you guys use. It ever did it with my old motor and i can sometime drive weeks with the light stays off. It did it this morning and i need to get this fix b/c i need state inspen in a mouth. I hoping not a crack head or something cause i at school and i have to go home to do that. Thanks alot in adv sorry for spelling
Old Feb 9, 2009 | 04:32 PM
guitarking135's Avatar
guitarking135
You may have a bad cap or a cut in your wires or something fouling out. I would go through and change out that stuff unless you have already and see if that fixes it... start cheap.
Old Feb 9, 2009 | 06:14 PM
dodgeboy7's Avatar
dodgeboy7
Yea i know start with the basic i did all that and it all new
Old Feb 9, 2009 | 06:18 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What exhaust set up do you have? Check the cat and the plenum to be safe.Other than that, hook up a fuel pressure gauge so you can monitor it under those conditions where you get the misfire code.
Old Feb 9, 2009 | 06:20 PM
dodgeboy7's Avatar
dodgeboy7
just did the kegger mod with the huges plate and brand new high flow cat with the y pipe and then a cherry bomb exteme
Old Feb 9, 2009 | 06:35 PM
zman17's Avatar
zman17
Then try the fuel pressure test I suggested. Hook it up and mount it out the hood to the wiper or something , so you can see it.
Old Feb 10, 2009 | 10:27 AM
dodgeboy7's Avatar
dodgeboy7
i hook my fuel pressure gauge up duct tape it to the windsheld and drove around it fine i stays a little above 50psi
Old Feb 10, 2009 | 11:08 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
First of all, you state that you're getting a misfire code, but no misfire. Well, you're mistaken, because there obviously *IS* a misfire or else the code wouldn't be tripped.
Have you checked that the plug wires have been routed properly per the TSB? When you rebuilt the engine, did you replace and/or inspect the heads? Is the distributor aligned properly?
Old Feb 10, 2009 | 12:31 PM
Formosa Joe's Avatar
Formosa Joe
Check this link for proper wire routing.
http://autorepair.about.com/cs/faqs/l/bl654h.htm
Joe
Old Feb 10, 2009 | 03:22 PM
dodgeboy7's Avatar
dodgeboy7
what i mean is there is a misfire codes but you cant feel it or hear it and it miss fire on all eight i would feel something and the motor was a rebuilt by a motor shop i got it as a long block. And yes the wires are corr i check them. the cam and crank sens were senked after checking the timing.
