new toys coming...
Old Feb 10, 2009 | 03:04 AM
BlueBeast2's Avatar
BlueBeast2
Sweet I plan on putting in some gauges when ine goes back together. I have a Auto meter cobalt wide band already and gonna get the same trans temp as you. Take plunty of pics please. Good luck with the install. Also if you could let me know when you do it if that a piller pod replaces the stock one or if you have to mount it to the stock plastic.
Old Feb 10, 2009 | 08:13 AM
xskylinedx's Avatar
xskylinedx
Originally Posted by aim4squirrels
I'm going to have my exhaust guy drill and weld a new O2 bung. I have read that you can use a wideband for the PCM, but you have to rig up some extra crap to keep the PCM from freaking. Not worth it, IMO.
+1 Thats what I will be doing when I get the money for a wideband.
My pillar gauge pod came with 4 tabs that required me to drill holes threw both pillar covers
then install to hold together, not cool looking at all. I decided to get some strong plastic
specific glue, scuff the edges of both mating surfaces, glue, and then clamp together.
Everyone thats been in my truck can't believe its not factory, just food for thought.
Old Feb 10, 2009 | 08:27 AM
aim4squirrels's Avatar
aim4squirrels
I had seen that. Mind telling me exactly what glue if you remember? I had seen some Automotive GOOP glue. I've had good luck with Amazing GOOP before and wondered if the automotive brand would work well
RM_Indy's Avatar
RM_Indy
To secure mine to the stock pillar I found the smallest plastic plugs I could find (Autozone I believe) and painted them to match the pillar/interior. I used 6 plugs cause with 4 it slightly bowed out in the middle. Can see them if you look very close at the pic with the pillar lieing on the rolling table.
Old Feb 10, 2009 | 08:28 AM
aim4squirrels
Actually, Mayfair in the CTD section has done a really great write up on it already. The pillar pods do not replace the stock pillar unfortunately. I did read somewhere that if you have the aftermarket tweeters in the pillar, that it might just be easier to order a standard A pillar from the dealership and hack on that one.
Old Feb 10, 2009 | 08:34 AM
aim4squirrels
Originally Posted by dodgeram07
sweet!!!... do you have link for the Sonnax sure cure kit?? i have been looking at transgo but the few past thread have me looking around
(pm sent, i hope)
go to the Sonnax website, they list their vendors there. Also try this:
http://www.transmissionpartsusa.com/...-sc4647rhe.htm
Just don't buy em out, OK?
Old Feb 10, 2009 | 09:08 AM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Originally Posted by RM_Indy
Make the effort of a new go-stick get a reasonable one so you wont be disappointed like I was with the first one.
Please excuse my ignorance, but what is a "go-stick?"
Old Feb 10, 2009 | 09:16 AM
xskylinedx's Avatar
xskylinedx
Wish I could remember. I just remember I picked up some plastic specific stuff. I think it may
have been one of those dual tube apoxys with a plunger. I used duck tape to clamp them
together because its more form fitting.
Old Feb 10, 2009 | 10:02 AM
aim4squirrels
you already have one, it's a camshaft.
Old Feb 10, 2009 | 10:17 AM
Rex-TheDOGG
DUUUUUUHHH!!
In the same vein as "bumpstick." Should have known.
Thanks.
