cold air intake vs. Top hat style
Old Feb 10, 2009 | 02:14 PM
guitarking135's Avatar
guitarking135
about how much are we looking to spend on a round filter and everything needed to put it on?
Old Feb 10, 2009 | 02:30 PM
Silver_Dodge's Avatar
Silver_Dodge
It can be done for less the $40 with the cheap 14x3 assemblys you can buy at about any auto parts store plus a stand alone breather and and s-bolt. The Mopar setup I run (see pic) was about $90 for all the same stuff, just looks a little better I think.
Old Feb 10, 2009 | 02:33 PM
guitarking135
I seen the diy on this but I'm still kinda confused about what parts I need can some one help me I understand the S bolt and the filter but what exactly is a breather? and the hose that comes out of my block what do I do with that?
Old Feb 10, 2009 | 02:47 PM
dakotas ram's Avatar
dakotas ram
you put the breather where the tube comes off of your valve cover
on silver dodge's 2nd pic you can barely see it at the back
Old Feb 10, 2009 | 02:49 PM
Silver_Dodge
The stand-alone breather replaces the hose that goes into the valve cover (not the PCV, the other valve cover). Hose out of your block???????
Old Feb 10, 2009 | 03:16 PM
Acapalic's Avatar
Acapalic
Yeah you guys got me , didnt mean to say more air , but that ended up coming out...... oh well. the top hat airfilter i had happened to be the same size as the throat of the throttlebody. I would have attached it using a S bolt but the K*N i had, the mounting bolt broke so i used the hose clamp that came off the stock air filter housing. For my Air breather , i bought a Spectra Filter Breather and its been working GREAT!
Old Feb 10, 2009 | 05:16 PM
guitarking135
so how does the filter fit on there? just that bolt in the center or is there a gasket of some kind that fits on the throttle body?
Old Feb 10, 2009 | 05:53 PM
guitarking135
does the breather just slip on there
Old Feb 10, 2009 | 05:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Have you not looked at this? https://dodgeforum.com/forum/2nd-gen...er-update.html
Old Feb 10, 2009 | 06:11 PM
guitarking135
yes yes I have but its not the best thing in the world either. I'm not a mechanic by any stretch I can do somethings but theres alot that I don't know. theres alot of stuff that thread leaves out or doesn't clarify.
