oil pressure problem
Old Feb 10, 2009 | 07:23 PM
geggle's Avatar
geggle
Default oil pressure problem
Okay.....I changed the oil press sensor on my 2001 Ram 2500 V-10. Gauge now reads no pressure. I checked voltage from sensor leads (6v) with ignition on. Next step is to check oil pressure with a manual guage. Where is the easiest place on a V10 to hook one up?
If it shows no pressure, i suspect I need to replace the oil pump. does anyone have a better suggestion? Anyone ever have the pleasure of replacing an oil pump on a V10? If so, what am I getting into?
Hopefully the gauge is just reading wrong, but I won't know until I hook up a manual one and check it. That is if I can figure out where to install it. I still can't believe that there is NO pressure since the engine sounds fine. No knocks, or lifter noises. But I'm not an expert, I hope one of you can steer me the right direction.
Old Feb 10, 2009 | 09:01 PM
helms's Avatar
helms
i would hook the manual guage to the same spot as the electrical sending unit. if the engine sounds fine then you still have pressure, it doesnt take long with no pressure to seize an engine. if there isnt any pressure at the sending unit, then there is probobly a block in the gallery, i dont know anything about the v-10s except they are v-10s, sorry i cant give you any specific advise
