new member old 1997 ram
Old Feb 13, 2009 | 09:53 AM
paul west's Avatar
paul west
Thumbs down new member old 1997 ram
remove gas tank i think gas filter is cloged? when i hit the gas it bogs down ?when gas prices are high i let the gas get real low what could it be thanks paul
Old Feb 13, 2009 | 10:12 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
Hey Paul. Welcome to DF!
Could very well be the filter, pump would do something similar. Might even be something common on second Gen rams. I'll move your post over to the 2nd Gen Ram section, they might be able to better help.
Old Feb 13, 2009 | 11:12 AM
RM_Indy's Avatar
RM_Indy
Hi Paul and welcome aboard
If you add info to your profile we will know what your driving
Any other symptons with this bog?
Could be plugged fuel filter, could be plugged cat, could be a leaking plenum gasket. Need a tune up? Recent purchase or owned a long time?
Old Feb 13, 2009 | 11:20 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
My money is on a clogged cat. Take it to a muffler shop where they can pressure test it. A plugged cat is indicative of another symptom, such as bad O2 sensors, plugs, etc as the cat should never need replacing.
Old Feb 13, 2009 | 05:50 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And if the cat is bad, don't just replace it without making sure the plenum gasket is not blown. http://dodgeram.info/tsb/2000/09-05-00.htm
Old Feb 13, 2009 | 07:33 PM
TurboABA's Avatar
TurboABA
It's not the best idea to run the tank down to the last drop (but let's face it, we've all done it). Usually, if there's any crud floating around in your gas, when you let the level drop really low, chances are that crap will get sucked into the pump and clog things up. Have the fuel pressure tested to see if it's low.
Old Feb 13, 2009 | 07:40 PM
96RamSLT's Avatar
96RamSLT
it could be a clogged injector to.. try like chevron techron fuel additive or lucas or something see if it goes away.. do you have ne problems starting after its been sitting for a while... this could b a fuel pump issue.. did you make sure your air filter isnt clogged up..
Old Feb 13, 2009 | 09:44 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I doubt that would happen. The sock and the internal filter are going to weed out anything down to almost Micron size particles. I have an old fuel pump I should break open to educate people here as there's a lot of misinformation out there about them.
