Bent Tie rod
Old Feb 13, 2009 | 06:35 PM
vmann's Avatar
vmann
Default Bent Tie rod
Went mudding today and ended up bending my tie rod. Whats a good one to get and how hard are they to replace? its a 4x4. When i turn to the left its fine but when i turn to the right it sounds like its grinding and there is yellow fluid leaking.
Old Feb 13, 2009 | 06:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Which tie rod? And where is yellow fluid leaking from?
Old Feb 13, 2009 | 06:46 PM
vmann's Avatar
vmann
front tie rod and its leaking from the silver bar when its turned. Ill try to post a pic soon
Old Feb 13, 2009 | 06:51 PM
zman17's Avatar
zman17
There is left and right tie rods dude! And I don't know of any silver bars that will leak yellow fluid. Spend the 15 bucks and get a Haynes manual or download the one in the Merry Christmas thread.
Old Feb 13, 2009 | 06:57 PM
TurboABA's Avatar
TurboABA
Are you sure you're talking about the tie rod? And there's no fluids in them, so you're either leaking PS fluid or diff fluid, and neither one should be yellow.
Take a really close look and make sure you find the source of the leak.
Replacing an outer tie rod is fairly easy.... the worst part of it is trying to break loose the old one.
Old Feb 13, 2009 | 07:01 PM
vmann's Avatar
vmann
here are the pictures. I thought this was a tie rod but correct me if im wrong. You can see the little dent in the casing.
Pictures:
Old Feb 13, 2009 | 07:11 PM
TurboABA's Avatar
TurboABA
Here's the tie rod, nearly impossible to "bend".
Old Feb 13, 2009 | 07:13 PM
TurboABA's Avatar
TurboABA
That's your steering stabilizer. Basically a shock or dampener. That explains the yellow fluid. Get a replacement one, possibly an upgrade. Shouldn't cost too much. Two bolts and it should come out easy.
Old Feb 13, 2009 | 07:26 PM
TurboABA's Avatar
TurboABA
Here's an example of a replacement unit
http://store.summitracing.com/partde...04+4294854552+
Old Feb 13, 2009 | 07:29 PM
Viper37's Avatar
Viper37
Oh my god I just laughed so hard.
Your steering stabilizer is shot. Replace it.
