3 inch lift kits question?
Old Feb 18, 2009 | 12:58 PM
gipperkid's Avatar
gipperkid
Default 3 inch lift kits question?
How come with a 3-inch Skyjacker lift they give you 3-inch lift coils, but only give 2-2 1/2" rear lift leafs? I am going to get the 3-inch Rough Country lift, but it comes with rear blocks. I am not about to stack the blocks to achieve lift. So I figured just buy an AAL. But will the truck sit higher in the front with 3-inch coils and only 2 1/2 inch leafs in rear? Or will it all just level out fine? Thanks.
Old Feb 18, 2009 | 01:04 PM
Mowhawk's Avatar
Mowhawk
Should level out fine. Front of ram sits 1/2 inch lower than the back.
Old Feb 18, 2009 | 01:36 PM
gipperkid's Avatar
gipperkid
Thats what I thought. my Dodge has 5-leaf springs, so I shouldn't have any problems installing an AAL?
Old Feb 18, 2009 | 01:41 PM
Silver_Dodge's Avatar
Silver_Dodge
You will want to get new u-bolts. The added leaf may make your current u-bolts too short, plus it is considered a bad idea to reuse the u-bolts even if they are still long enough.
Old Feb 18, 2009 | 01:48 PM
MudRam99's Avatar
MudRam99
Not mention it makes the whole process a lot easier! Just cut the old u-bolts instead of fighting them! Replace with new, much simpler operation.
Old Feb 18, 2009 | 02:19 PM
gipperkid's Avatar
gipperkid
Thanks for the input, I worried the front would be higher than the rear.
Old Feb 18, 2009 | 02:22 PM
Silver_Dodge
When I put that leaf on, it was stiff enough that the rear was still higher then the front. But over time, it settled down, and my truck is pretty well level now.
Old Feb 18, 2009 | 02:39 PM
Viper37's Avatar
Viper37
Originally Posted by Mowhawk
Front of ram sits 2 1/2 inch lower than the back.
Fixed.
Old Feb 19, 2009 | 12:48 AM
Mowhawk's Avatar
Mowhawk
mah b lol My ram sits half inch lower but i forgot i have the Off road
Old Feb 19, 2009 | 12:54 AM
BlueDemon01's Avatar
BlueDemon01
Is it still a good idea to get new control arms?
