rebuilt trans prob
Old Feb 18, 2009 | 03:48 PM
madman269's Avatar
madman269
Default rebuilt trans prob
so we had a rebuilt trans put in our truck....it went in fine,,but.....after about three miles the trans temp lite comes on and the trans will come out of o/d..then when you come to a stop it will not shift out of first....let it sit and it repeats....they have hit it with a temp gun and it only reads 140 to 150 degrees so its not hot...have checked all lines no restrictions..the mechanic thinks it maybe the trans temp sending unit on the valve body....but the person that we purchased the trans from says that all sensors and servos are tested and or replaced during the rebuild....the person that we purchased the trans from is saying a bad connection or grounding in the harnness my mechanic is not a trans specilist.....so he is kinda hit and missing...looking for some direction.....1996 ram 1500 46re trans.....
Old Feb 20, 2009 | 07:05 PM
madman269's Avatar
madman269
took the truck to dodge...rebuilt tranny was sent out with the wrong pressure solinoid...round instead of square or some ****..the guy wanted us to pay for shipping both ways from calif to new jersey..thats another 1000.00 dollars...and then the labor om the repair.....another 400.00... said screw you let dodge here fix it.....350.00 dollars done works great.......so if you go to by a rebuilt tranny...dont buy one from toms transmissions in new jersy..they are a joke.....and by the way... this my last post in here....i cant get any sound solid info from you idiots........respond all you want....because i need mechanic help....not bull****.....
Old Feb 20, 2009 | 08:46 PM
96RamSLT's Avatar
96RamSLT
listen.. same exact thing was going on in my rebuilt trans in my 96.. this is an easy fix.. theres a small check valve going in to the motor, this check valve allows coolant to circulate and cool the tranny by going thro the radiator. long story short, this check valve is a pos. it constantly clogs and can happen any time. this is what you do. take the check valve off youll see two of them.. passengers side right by the radiator about 12 inches long. go to auto zone buy some trans fluid line about 12 bucks a foot.. replace the check valve thats closest to the motor with the line. use 2 hose clamps on both ends to prevent a blow out of the line. and your in business my friend. but dont drive it any more until thats fixed. its not circulating your tranny fluid and it will fry your freshly rebuilt tranny.. trust me.. mine did. so im on rebuilt tranny number 2. in 200 miles.
Old Feb 20, 2009 | 08:47 PM
96RamSLT's Avatar
96RamSLT
now that i just read ur second post.. thanks for being an A$$hole.. i just basically told you how to save your tranny for a mere $20. F*ck You
Old Feb 20, 2009 | 11:33 PM
transguy37's Avatar
transguy37
Wow, that's crazy, they should have known that one. 96 to 99 takes the round governor pressure sensor, which also is the trans temp sensor, and 2000 and up takes the square one. If you mix these up, on the scanner you will see -30 degrees or somewhere around that for the trans temp. Will never work.
Old Feb 21, 2009 | 10:29 AM
aim4squirrels's Avatar
aim4squirrels
Bye bye!
Old Feb 22, 2009 | 09:42 PM
MonteC's Avatar
MonteC
Note to self: do not help madman when his toms transmission goes out.
