is this all i need for 4.10 gears ??
Old Feb 18, 2009 | 06:46 PM
lastrights's Avatar
lastrights
Default is this all i need for 4.10 gears ??
i have the nasty 3.55. is this all i need to change to 3.55 to 4.10 for both front and back ?http://cgi.ebay.com/ebaymotors/94-01...Q5fAccessories
Old Feb 18, 2009 | 07:10 PM
helms's Avatar
helms
if you have 3.55s now you have to either get a 3.91 and up carrier, or get a "thick" 4.10 ring gear for the 3.55 carrier. That one you specified specifically said NOT for the 3.73 and down carrier
Old Feb 18, 2009 | 07:51 PM
aim4squirrels's Avatar
aim4squirrels
you also need a master install kit for each axle. You can get away with a basic install kit, but it's better to have all the parts on hand if something's damaged.
Old Feb 19, 2009 | 12:04 PM
gipperkid's Avatar
gipperkid
I see people talk about these "thick" gears, but I have yet to find out what they are talking about.
Old Feb 19, 2009 | 12:41 PM
PurplDodge's Avatar
PurplDodge
That is only for the front.
Old Feb 19, 2009 | 12:43 PM
98cherryram's Avatar
98cherryram
what do you mean by a carrier??? and where do we get one?
Old Feb 19, 2009 | 07:08 PM
helms's Avatar
helms
because the different gear ratios use a different amount of teeth on the ring gear and pinion gear, the sizes of each change. As you get into lower gears (numerically higher), the pinion gets smaller and smaller. Because the difference in pinion size between 3.55s and 4.10 is so drastic, the teeth couldnt mesh with the ring gear properly because they are too far away from each other. The different carrier will have the ring gear flange already closer to the center. but if you dont have one, then you will have to get a thick gear, which is physically thicker, to move it close enough to the pinion to have a proper mesh.
The carrier is the peice that you see when you pull the diff cover. It is what the Ring gear, spiders and side gears all mount to.
Old Feb 20, 2009 | 10:06 AM
TMS Bill's Avatar
TMS Bill
Well said. You paint an excellent verbal picture.
Old Feb 20, 2009 | 10:13 AM
dodge15004x45.9's Avatar
dodge15004x45.9
So is there any webiste out there that have a hole kit to do front and read diff. With everything you need to do it?
Old Feb 20, 2009 | 02:37 PM
helms's Avatar
helms
im not sure about that. but its not too complicated, if you have a 3.73 and down carrier (which you do) just find a set of "thick" 4.10s. there isnt really anything else you need, im assuming your going to take it to a shop to get done, correct? just call themand tell them you want 4.10s and they will sort it out. if you really want to do the shopping yourself, just worry about the gearset, the shop will get things like crush sleeves and shims.
