My New Exhaust.......
Old Feb 21, 2009 | 11:38 AM
dakotas ram's Avatar
dakotas ram
yeah, all it does is give you threads....if ya wanted to go thru the trouble, you could cut your old bung out but the nonfouler is cheap
Old Feb 21, 2009 | 06:43 PM
dakotas ram
heres a vid.......quality is crappy, ill try to get a better one some other time....go to my other vids and i got one of the gutted cat that i took off.......
http://www.youtube.com/watch?v=QLKCpnPVMUY
Old Feb 21, 2009 | 07:01 PM
96RamSLT's Avatar
96RamSLT
sounds pretty good man
Old Feb 23, 2009 | 02:02 PM
dakotas ram
alright, i made a side pipe for it today.......
it really quietened it down on the inside and got rid of the drone, but it still has a good tone to it......gonna either put this on as a tip......
or make one out of these old tips......
Old Feb 23, 2009 | 04:14 PM
dodgeram07's Avatar
dodgeram07
looks pretty damn good i think( the one you have on there now, the flat cut)
Old Feb 23, 2009 | 05:21 PM
hometheaterman's Avatar
hometheaterman
That first tip looks pretty good. With the old ones I think it would look fine with one tip but if you made it have dual tips I don't think it would look as good.
Old Feb 23, 2009 | 06:08 PM
Jpnorris87's Avatar
Jpnorris87
If you go down to a lighter wire it will prolly be hot enough to weld your exhaust on the low setting. The lighter your wire is, the hotter it will weld on each setting. The only problem you might have is that it might be too hot on the high setting and just splatter your weld every where. And if it that doesnt work, just move faster!
Old Feb 24, 2009 | 01:43 AM
dakotas ram
yeah, i got some lighter wire and it works alittle better......im still refreshing myself tho.....
Old Feb 28, 2009 | 07:48 AM
mcss8541's Avatar
mcss8541
Originally Posted by dodgeram07
sweet thanks, but what does the non fouler do?? does it make a thread hole for the o2?
yes it does. i did the same thing to the straight pipe behind the cat. put the non fouler in a vise and take a hacksaw and cut off the nut hexagon head and toss the bottom portion. drill a hole in the area and test fir the tip of your O2 sensor to make sure it fits ( 18mm hole should do it because that's the size of the nonfouler) then weld it in place.
Old Apr 24, 2009 | 10:13 PM
dakotas ram
Default update!!!
i ended up using my 4in tips and making a dual tip......not the greatest flow, but itll work for now......
