AiRaid or K&N
Old Feb 26, 2009 | 05:34 PM
  #21
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by iwhitne
people... thinking about it... $300 for a K&N.... or $15 for a 14x3... both will give you the same results!!
Thats what I basically have been saying to. If your only two choices were the K&N (or a cheaper copy of the K&N made by some other company) and 14x3, I'd get the 14x3, hands down. They both do the same thing, neither get cold air, so go with the cheaper one.
The only thing that comes close to a real CAI kit is a Volant type system or ram air.
Old Feb 26, 2009 | 07:06 PM
  #22
wjxavier's Avatar
wjxavier
Wow... do you understand anything about physics?
The heat "transfer" you are talking about... if by "transfer", you mean to allow heat to reach the air inside the kit, the only way for this "transfer" to take place is for the material the kit is made of to absorb the heat first. Once it gets hot enough by absorption, the heat reaches the air inside it. So if a certain metal absorbs heat better than a certain plastic, that same plastic cannot "transfer" more heat than the metal. This of course assumes we are talking about fully enclosed kits. The K&N type heat shield allows air above and below it, it does not seal tightly at all with much of anything around it, and so really isn't that great of a heat shield, regardless of the material its made of.
yea you're probably right. i was just questioning it because of the fact that my father and i put in radiant heating in floors...and we use plastic piping and i figured that since we use plastic, maybe it's because it transfers heat better. i guess its just the ease of installing it maybe.
