Fog Light Retrofit
Old Feb 27, 2009 | 02:54 PM
  #21
Viper37's Avatar
Viper37
Originally Posted by J415
Hey TMS Bill, the picture you took of that harness IS NOT a fog light harness. I don't know what it is, but it's not a fog light harness. the harness is suppost to be under the radiator more or less in the middle. It's oval with 2 blue wires and one black. The one you took a picture of, I have that harness to and I STILL don't know what it's for either.
According to the diagram on page 1112 of the service manual, that is connector C106. C106 has 2 forms. One of them is closed with what appears to be a terminated plug, the other is open.
C106 is connected to G107 20GY. According to the diagram, Pin G107 20GY is listed as "4WD SWITCH SENSE"
C106 also has a listing for connection G107 18BK/GY. (Z1 18BK are both grounds) This took me to this connector:
And there you have it, those connectors are connectors for some sort of 4WD sensor.
Old Feb 27, 2009 | 03:21 PM
  #22
Rex-TheDOGG's Avatar
Rex-TheDOGG
I'm just curious if any one can tell me what the wire colors are on the harness that connects to the fog light switch. the haynes manual "conveniontly" skipped that part.
I have a '98 Ram and a 1994-1998 Ram Haynes manual. The fog light switch shown in it has what looks like a 6-pin connector (C226) with 5 wires going into it: 1) Broun/White wire -- Fog Relay #2 Coil; 2) Black wire -- Fog Switch to ground; 3) Black wire -- Fog Switch Ind to ground; 5) Orange wire -- O/D Switch Illum. Lamp; 6) Lt. Blue wire -- Fog Switch Ind power.
Fog Lamp Relay #1 de-energizes the fog lamps circuit when the hi-beams are on. Fog Lamp Relay #2 energizes the fog lamps circuit when the Fog Lamp Switch is closed and Fog Lamp Relay #1 is de-energized (no hi-beams).
Hope this helps.
Old Feb 28, 2009 | 03:12 AM
  #23
J415's Avatar
J415
REXX your the man, thanks for the info. All I ever needed was to know what they do and where they go. I'll take it from there. thanks again!!!
Old Oct 14, 2013 | 09:44 PM
  #24
joseortizservin's Avatar
joseortizservin
Exclamation Can you Help Me?
Hey mjackson92rs can you tell me what size the bolts and washer size that you used. I am also trying to add fogs to my truck because my headlights keep turning off on me. Thanks
