front wheel hub
front wheel hub
ok, i finally got to drive my truck all the way home to NY. I LOVE NY.
i got hee and the truck ran great, now i went to fix my rear bvunmper, and change the front tires, got that all done and drivng home.
in the process of drivig home, that new front wheel hub some of you may remeber me getting replaced, went out again..... I AM PISSED
now i am going to do it myself this time. i found a hub on ebay for about 80bucks, but it does not specify right or left. DOES THIS MATTER?
Trending Topics
yea, i will check the ball joints while im in there. and i will probably be checking jsut baout everything i can on there too... just make sure. along with the alignment.
but i know its the hub, i just had them replaced, by dodge, and they were over torqued, tehy were at at least 225ft lbs, abnd when i just put my two new front tires on with the 15" wheels, i pulled the caliper and rotor off and it was when you turned the hub, it made some grinding noises. so i knew it was going, but i had just drove home from NC to NY so i figured it would have been fine...
but thanks for the info and i will be posting some pics of the truck with the new wheels and bumper (front being built myself) on there...
