overdrive switch BROKEN?
Old Sep 14, 2010 | 09:09 PM
  #21
Augiedoggy's Avatar
Augiedoggy
Originally Posted by Maxx_Magnum
I would just replace the switch, I've never seen an auto transmission handle break before, unless you are doing some serious cranking on it
I imagine these are probably almost the same as in the Rams, but you might have better luck here in the Durango section https://dodgeforum.com/forum/1st-gen-durango-69/
Good luck with it!
my dad had a ferd truck that you needed to pick the lever up off the top of dash and insert into broken colum to shift then set back on dash....it was a beauty...
Old Jan 8, 2015 | 08:48 AM
  #22
2besst's Avatar
2besst
my switch has a dim light when on and gets brighter when turned off? not an all the time thing..... bad switch?
Old Jan 8, 2015 | 10:00 AM
  #23
Or bad ground somewhere? What year is your truck?
