Thumping sound in front end????
Old Mar 1, 2009 | 07:19 PM
revvinram's Avatar
revvinram
Default Thumping sound in front end????
I am hearing a thumping sound from the right front on hard left turns, its a 2wd ext cab. upper and lower ball joints are about 3 yrs old, monroe sensa-trac shocks are about 2 yrs old and tight, front end is well greased. Any idea's??
Old Mar 1, 2009 | 07:24 PM
bgibb68's Avatar
bgibb68
wheel bearings, sway bar bushings, any of the ball joints, etc
Old Mar 1, 2009 | 07:25 PM
helms's Avatar
helms
youll have to check all your bushings and balljoints, even though they arent that old yet.... these are Dodges after all. I also remember someone here was talking about a GM pickup and the engine mount was toast and it was doing close to the same thing, worth a peek
Old Mar 1, 2009 | 07:28 PM
helms's Avatar
helms
on another note. my instructor in school told me about a repeat customer that came into the shop with a clunk while turning, they finally found a snap-on air ratchet in the fenderwell that was left there at the factory... customer is happy with a free fix, the tech is happy with a new snap-on air ratchet, everyone wins... lol who knows, you might get lucky
Old Mar 1, 2009 | 08:28 PM
Viper37's Avatar
Viper37
Make sure your sway bar hasn't slid to one side or the other. If it has it will drag on the spring perch.
If you have a leveling kit or modified geometry, your spindle is dragging on the spring perch at full droop.
Both are problem's I've had.
Old Mar 3, 2009 | 03:11 PM
revvinram's Avatar
revvinram
Default Update!!
Brought it over to have it looked at today and it turns out the Idler Arm and Pitman arm are worn out!!!!
Thanks for your help!!
