Surgin around 40mph and stalling after warmed up.Help?!
Old Mar 1, 2009 | 11:00 PM
dirtoutlaw88's Avatar
dirtoutlaw88
Default Surgin around 40mph and stalling after warmed up.Help?!
Truck is a 94 1500 5.2L Truck starts and runs fine till it warms up and then it will begin to surge and rpms will jump around 200 when it does this. Only surges when foot is slightly on pedal give it more pedal and there is a slight delay and it comes back alive. Also, at a stop light or sittin in park it will be idling fine and suddenly get rough and then drop rpms to the point where it used to complety die. I replaced the EGR valve, Idle Air Control and took off the throttle body and completely cleaned all the vacuum holes and butterflies. Seems to run much better while under acceleration, but my original problems still are there with surging and wanting to die, sometimes it won't die completely but will Hiss very loudly and chug while rpms bounce between 50 and 100. My next thought is to change out the TPS, when its chugging and I unplug the TPS it revs back to normal idle very quickly and then resumes rough idle again. then revs again when it is reconnected and back to rough idle once again. However, when it starts acting up if I turn off the ignition then re-fire, the problem is gone for a little while then comes right back. Shutting off and re-firing while driving stops the surging also, then return after 5 miles or so. ANY IDEAS?! I've been fightin this thing for weeks now tryin to get it to run right. I'm about at wits end. Any help would be awesome guys...Thanks so much!
Old Mar 1, 2009 | 11:04 PM
dodgeram07's Avatar
dodgeram07
did you every reset the computer?.........or maybe a bad torque converter because does it die in park or drive?
Old Mar 1, 2009 | 11:27 PM
aim4squirrels's Avatar
aim4squirrels
pre-cat O2 sensor. Replace it and it should run fine.
Old Mar 2, 2009 | 06:28 PM
dirtoutlaw88
Well I checked the TPS with a voltmeter and it was giving me erratic values from idle to mid throttle. It seems to accelerate much better with a new TPS. Yes, I have reset the computer each time I've replaced a part. It will struggle to stay runnin no matter what gear it is in, giving it gas is the only thing to bring it back or shutting it off and re-firing. Code reader is tellin me part throttle TC lock up solenoid has a open/short, but its not reading any code for O2 sensor. Are there any other checks to validate the TC is still ok, or to check the O2 sensor with a multimeter? Also, how confident are you in the O2 sensor fixing the stall and surge? I sure do appreciate your help guys, this is my first mopar and don't know too much about em...yet! lol
Old Mar 3, 2009 | 07:50 PM
dirtoutlaw88
on this truck there is only 1 o2 sensor right? located in the front of the Cat converter?
Old Mar 3, 2009 | 08:11 PM
mcss8541's Avatar
mcss8541
check your MAP sensor this can cause surging as well.
Old Mar 5, 2009 | 08:03 PM
dirtoutlaw88
Is there anyway to clean the MAP sensor, it had rustly powder come out of it when I cleaned the throttle body last week. AIM4Squirrels...Is there just the 1 O2 sensor that screws into the front of the Cat?
...Has anyone replaced the Torque converter lockup solenoid before?...any tips I should know about or is it pretty straight forward? Drop the pan and filter and Valve Body, then replace? Thanks for all your help thus far!
Old Mar 5, 2009 | 08:56 PM
aim4squirrels
Marty over at KRC has stated that typically any time a vehicle starts to stall and die, ESPECIALLY after the truck enters closed loop, the first and most likely culprit is the O2 sensor.
Depending on the truck, it could be 1, 2, or even 3 upstream sensors.
Old Mar 5, 2009 | 11:23 PM
dirtoutlaw88
Anyone know about the TC lockup solenoid, or a link?
Old Mar 6, 2009 | 12:19 AM
dakotas ram's Avatar
dakotas ram
you should only have 1 o2 sensor
