Parts truck question
Old Mar 3, 2009 | 10:03 AM
Coyote Jack's Avatar
Coyote Jack
Default Parts truck question
I am looking at buying a parts truck to keep my 98 Ram 1500 4x4 up to snuff. Other than the dash, is there many differences between 1994 to 2001. I am mostly interested in drivetrain and suppension but any info on body parts would be helpfull to. Does it matter much if I find one with a 5.2 or a 5.9? Mine is a 5.2. Any tranny differences? Transfer case? Differentials?
Jack
Old Mar 3, 2009 | 12:17 PM
01dabram20's Avatar
01dabram20
94-97 have different interior pieces and seats. the 98-01 have different dashes and seats mainly. almost all the other should work but I don't know about the tranny.
Old Mar 3, 2009 | 01:12 PM
Coyote Jack
Thanks 01dabram20,
That is pretty much what I thought. I was also wondering about the difference between a 1500 and 2500. It's pretty much everything suspension wise is just a little heavier isn't it?
Jack
Old Mar 3, 2009 | 01:15 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
94-96(?) engines use the EGR. My 1997 doesn't have the EGR. I don't think this truck will be of a benefit for you unless you're getting it for a good price and can make more than your money back parting it out.
Old Mar 3, 2009 | 02:23 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What year is the parts truck? Pre 96 also is OBD1, so the PCM is different, and I don't believe the transmissions are the same. 46rh as opposed to 46re in the 98.
Old Mar 3, 2009 | 03:37 PM
Coyote Jack
The parts truck will be what I bid on. It is an auction. That is why I am trying to get all the info I can. So far I have been concentrating on looking at 97 to 00 trucks.
Jack
Old Mar 3, 2009 | 03:47 PM
zman17's Avatar
zman17
Bid on one with the same motor as you have also. The pcm is flashed different for the 318 , than it is for the 360.
Old Mar 3, 2009 | 04:11 PM
Coyote Jack
Wouldn't that be a matter of just changing out the PCM if I decided to use the different engine?
Jack
Old Mar 3, 2009 | 04:13 PM
zman17's Avatar
zman17
Yea, but if your buying a parts truck, why not get one as close as possible?
Old Mar 3, 2009 | 05:46 PM
PurplDodge's Avatar
PurplDodge
If you swap the PCM from another truck(don't matter if 318, 360) you will get a code unless you have the V.I.N from your truck flashed into the parts truck PCM.
