Old Aug 6, 2015, 02:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
How do you reset the pcm
Old Oct 26, 2014 | 09:20 PM
  #51
pjrenusr's Avatar
pjrenusr
Default ecu flash 360 gas
I know this is far reaching but it does concern a 98 dodge ram 360 with auto... I have installed it in a 66 Belvedere and the ecu is out of some Dodge product that had a 360 as well.. How do I or do i need to flash it... I have heard of shops that will reprogram and eliminate what I dont need and yet get the car up and running. Any help is greatly appreciated
Old Oct 27, 2014 | 04:07 PM
  #52
What year harness? 98 and up started using the central timer module for some communications.... which makes it complicated to install in anything else.
Old Feb 19, 2017 | 12:37 PM
  #53
line8014's Avatar
line8014
Originally Posted by Viper37
Turn it to crank for fastest effect.
Anytime you do an air filter, change engine parts or something like that you reset the PCM.
Would this also be done when changing parts in transmission
Old Feb 19, 2017 | 04:21 PM
  #54
What parts? Certainly wouldn't hurt though.
Old Feb 19, 2017 | 04:59 PM
  #55
line8014's Avatar
line8014
Changed the govenor pressure and sensor. Changed the reverse servo changed the T V cable adjusted bands still no reverse
Old Feb 19, 2017 | 05:00 PM
  #56
For a quick and dirty check, unplug the 8 pin connector to the trans, and try reverse again. If it still doesn't work, you have a mechanical problem, not electronic.
Old Feb 20, 2017 | 03:58 PM
  #57
line8014's Avatar
line8014
Pulled wire harness off pins came out what part is this to is it the TCM
Old Feb 20, 2017 | 05:45 PM
  #58
Pins came out of the connector at the trans?
Pretty sure you can get replacement pigtails. That harness is part of the main harness, and comes down from the PCM. (there is no separate TCM on these trucks.)
Did you have reverse with it unplugged?
Old Feb 21, 2017 | 02:47 PM
  #59
line8014's Avatar
line8014
No started truck no reverse
Old Feb 21, 2017 | 04:53 PM
  #60
That's a mechanical problem. Gonna have to dig into the trans.
