Hard shift from 1st to 2nd, 2nd to 3rd
Old Mar 5, 2009 | 10:27 AM
Hardpike's Avatar
Hardpike
Default Hard shift from 1st to 2nd, 2nd to 3rd
Have some shifting issues. I did a search all in the forum, found some close issues, but little different. 1st of all, the truck is a 94 1500 4x4 with the 5.9l, 126k on the clock. I have only owned the truck for the last 3,000 miles. don't know the history prior. I notice that when I accelerate quicker, it shifts hard (like a clunk) from 1st to 2nd. From 2nd to 3rd, it is not as hard, but does feel hard. Now if I go easy on the acceleration (like a Grandma), it shifts smooth. The transmission fells strong, I think, but I am no expert.
Here is what I have done so far. Changed the fluid in the transfer case, had 15 qts changed from the trans (Jiffylub complete trans service). Added Lucas trans stabilizer.
One thing that I did notice, is I get a clunk shifting from rev to drive. So I do have a broken u-join. Can it be related? Don’t know. Any help will be appreciated
Old Mar 5, 2009 | 11:19 AM
360dodgeram360's Avatar
360dodgeram360
if u have a broken u-joint your driveshaft should be on the ground.
Old Mar 5, 2009 | 11:38 AM
Hardpike's Avatar
Hardpike
broken or bad, there is a issue with the U-joint. Lets not derail the thread.
Old Mar 5, 2009 | 11:44 AM
360dodgeram360
i see. not trying to derail but i recently broke my u joint and my truck was immobilized. i guess it is possible that a bad u joint could cause that but i really dont think that is the case. you could try to have the bands adjusted thats what i am goin to try on mine. also, did they do a tranny flush or did they change the filter?
Old Mar 5, 2009 | 11:53 AM
Hardpike's Avatar
Hardpike
Thanks for the response. I had a whole tranny flush that included the cooler and T.C.. That included a new filter as well. I dont think the Band were adjusted. I just googled how to do it, and of-course the pan needs to be droped again. I got maybe 100 miles on the truck since I had the Trans serviced.
Old Mar 5, 2009 | 11:57 AM
360dodgeram360
that's all i can think of, hopefully someone else can offer better/more advice.
Old Mar 5, 2009 | 12:08 PM
deeznutts's Avatar
deeznutts
cple things you can try to do on your own with outtaking it to a pro,,is try adjusting the bands,but first and foremost,,do a search and if your mechanically inclined the least bit,,you shld have no problems,,,also theirs adjusting the tv cable...try those 2 things cable first and see if it helps.
Old Mar 5, 2009 | 12:13 PM
Hardpike's Avatar
Hardpike
Will try adjusting the bands and t.v. cable tonight. hopefully it works
