mopar hi-perf engine comp
Old Mar 5, 2009 | 11:38 AM
360dodgeram360's Avatar
360dodgeram360
Default mopar hi-perf engine comp
does anyone have one of these or like them? i was contemplating buying one for my 95 ram but they are expensive so i was wondering if it was worth it.
Old Mar 5, 2009 | 11:49 AM
Silver_Dodge's Avatar
Silver_Dodge
For a '95, it would be worth it simply because you don't really have any other options since you are OBD1. I had one on my '99, and it was better then the Hypertech programming I had before it.
Old Mar 5, 2009 | 11:54 AM
360dodgeram360
thanks, that sounds good. i guess i'll start saving up. how much increase are you supposed to have? did u feel a difference?
Old Mar 5, 2009 | 11:57 AM
Silver_Dodge
Ya, it was noticable. Nothing like my B&G though, but it was ok. You might have to run high octane though. I had to some time, but not all the time.
Old Mar 5, 2009 | 12:05 PM
deeznutts's Avatar
deeznutts
im running one in my 95,,and there was a noticeable difference spec in the torque department..but if memory serves me correctly,it only gives like .01 horsepower and like 20 torque,,,the most noticeable gains with them will be when you upgrade the other stock parts..(hedders,throttlebody,intake,etc)
Old Mar 5, 2009 | 12:09 PM
360dodgeram360
well i already have headers and super low restriction exhaust and intake so i could use more tq. i run mid grade gas. will that work or do i need premium? and hows the install? do u just bolt on the firewall and hook up those 3 looms to it and ur done?
Old Mar 5, 2009 | 12:10 PM
deeznutts's Avatar
deeznutts
check,,but with mine it says 93 only or i get pinging..yep,,easy install,,take out the bolts holding the old one on,,,and replace with your new one,,,shop around and try too find a good used one...i got mine from bionicdodge.com,,from someone else...seems i paid 100.00 for it plus shipping.
Old Mar 5, 2009 | 02:03 PM
RM_Indy's Avatar
RM_Indy
Remove the 3plugs, 3screws and remount the MP PCM and plug it back in. Simple swap.
By mistake I filled my 96 with 87oct and didnt get ping. Probably get away running mid grade gas but in summer heat &/or towing run 91oct. I saw a small mpg increase when I added one to my 96 while using 91-94oct.
MP PCM on the 96 5.9 gave a claimed 20hp/26trq (crank) according to Mopar Performance (97 catalogue). KRC dyno sheet of MP PCM on a Dak RT showed a gain of .1hp/28trq at the wheels. Ive always been suspicious of that one time dyno test they did at KRC.
1/4m et reduction on my 96 Indy was .28 seconds. Very sizeable/noticeable gain that was more than many of the bolt on upgrades Ive track tested over the years.
I still have mine and will use it with the 408 to control the trans only(FAST saem).
