Maybe a costly repair
Old Mar 5, 2009 | 02:10 PM
Erik Kuijvenhoven's Avatar
Erik Kuijvenhoven
Default Maybe a costly repair
When i shift into reverse it makes a Bang not that load but deff loader than when i go into drive anyone had this start ??? is it a sign of my tranny going? Thanks guys
Old Mar 5, 2009 | 02:13 PM
ron333's Avatar
ron333
I would check the U-Joints first. What you've described sounds just like a failing U-Joint, and that's not an expensive repair.
Old Mar 5, 2009 | 06:23 PM
Erik Kuijvenhoven
Really I hope so how would I cheak that?
Old Mar 5, 2009 | 06:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You have a 2wd I assume? Raise the rear end, and get under it and see if you can move the shaft up or down, sideways or rotating left to right while looking at the joints on each end of the shaft. They should not move.
Old Mar 5, 2009 | 07:09 PM
Erik Kuijvenhoven
Cool Thanks guys Really appreciate it
Old Mar 5, 2009 | 09:16 PM
aim4squirrels's Avatar
aim4squirrels
Also check for any seepage in the U-joint cups.
Old Mar 7, 2009 | 05:17 AM
Erik Kuijvenhoven
what do u mean by seepage??
Old Mar 7, 2009 | 03:49 PM
dblj16380's Avatar
dblj16380
You should be able to climb under there and look to see if any grease is leaking out of the cups. Also you should grab your driveshaft and give it a quick shake near each u-joint. If it moves, then you've got u-joint problems. If it stays still, then your in the clear with those.
Old Mar 8, 2009 | 06:26 AM
Erik Kuijvenhoven
Cool Ya i think its my u joint thats making the bang it does make sense Man what a relief I thought it was deff my tranny u guys saved me some worries thanks
Old Mar 8, 2009 | 02:11 PM
dblj16380's Avatar
dblj16380
That's what we and this forum is here for!
