318 engine build up
Old Mar 5, 2009 | 05:22 PM
BigRedRam95's Avatar
BigRedRam95
Default 318 engine build up
Hi I have a 1995 ram 1500 reg cab with a 5.2 318. I am wondering if anyone could tell me what I should do to get some more horse power out of it. I have a intake system, throttle body spacer, and new injectors. what else should I do
Old Mar 5, 2009 | 06:18 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Take the throttle spacer off for starters. And if you don't want to spend a lot of money, I won't mention getting some Harland Sharp rockers and/or changing the gears.
Old Mar 5, 2009 | 06:46 PM
BigRedRam95
Why take off the tb spacer
and what would the rockers or the gears cost
Old Mar 5, 2009 | 08:45 PM
aim4squirrels's Avatar
aim4squirrels
TB spacers don't really work for our particular type of intake.
The air that's supposed to be "rifled" or "twisted" by those little fins in the bore of the spacer enter a big open area called the plenum where it waits for the next available runner to load. The air charge can't and won't maintain any supposed benefits of the spacer.
Old Mar 6, 2009 | 12:44 AM
dakotas ram's Avatar
dakotas ram
what do you mean by intake system?........headers and exhaust are a good start
check out this site http://www.bionicdodge.com/Download/...d%20Tricks.pdf
Old Mar 6, 2009 | 06:46 AM
BigRedRam95
I put a aem brute force intake system. It has a dry air filter and a box around the filter for a heat sheald.
Old Mar 9, 2009 | 04:22 PM
BigRedRam95
What gear ratio should I go with if I were to replace them
Old Mar 9, 2009 | 04:39 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
If you're doing a build-up, then bore it .030 over.
Old Mar 9, 2009 | 05:36 PM
zman17's Avatar
zman17
Depends on what you have now, and what you plan to do for tires in the future.
Old Mar 9, 2009 | 06:00 PM
BigRedRam95
I dont know what I have now how do I tell there should be a tag on the rear end to tell me right. now I have 31 inch tires and would like to go to 33 for next set
