Help with misfires?
Old Mar 7, 2009 | 11:00 PM
johnnyrocket5363's Avatar
johnnyrocket5363
Unhappy Help with misfires?
My 4x4 seems to be allergic to water. This is simply UNACCEPTABLE. When I nail a mud puddle, she'll spit and sputter for a short time this time, be fine others. Also, sometimes when driving in the rain, she'll complain. Once, the CEL started flashing and set a misfire code. My vacuum is slightly low, so could it be a leak to the transfer case or something (I also suspect a leak to the heater box)? My grandpa said that some mopars are just very susceptible to moisture (one of his cars would shut down mid-freeway in the rain). I, however, can't abide such. I have replaced cap, wires, plugs, coil. I have discarded the stock parts. Any thoughts?
Old Mar 7, 2009 | 11:24 PM
johnnyrocket5363
In addition to the above, I bought a previous set of wires at Advance. On a wet day, she missed like crazy. My dad and I cranked her up after dark, and you could see arcs of electricity all over the wires. I called Advance to complain, and they said that was normal (yeah, right). All they would do, however, was swap the set with another. Could these just be sorry wires?
Old Mar 8, 2009 | 12:41 AM
TMS Bill's Avatar
TMS Bill
It's not normal ... they're not supposed to do that. Do they still? If so ... there's your problem. Get a GOOD aftermarket set.
Old Mar 8, 2009 | 01:56 AM
dakotas ram's Avatar
dakotas ram
do the wire reroute and replace your distributor cap
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Old Mar 8, 2009 | 03:02 AM
TMS Bill's Avatar
TMS Bill
Or just replace the leaky wires with good ones and don't worry about it.
Old Mar 8, 2009 | 01:10 PM
johnnyrocket5363
I've done the wire route thing and bought little plastic separators for them. These WERE (advance's) "good wires". Is Auto Zone better? Or should I go to NAPA?
Old Mar 8, 2009 | 01:21 PM
TMS Bill's Avatar
TMS Bill
Did they have "Better" or "Best" wires? What's the diameter? I'd use no less than 8mm.
Old Mar 8, 2009 | 01:34 PM
dakotas ram
well i got autozone bosch 7mm and as far as i know theyre fine......
Old Mar 8, 2009 | 01:45 PM
aim4squirrels's Avatar
aim4squirrels
if you don't like shopping on the internet, your best bet is to go to the parts store and order a set of MSD superconductor wires.
You can also go to the dealership and get the Mopar Performance wires.
Also, I highly recommend using Dielectric grease on every terminal in the ignition system. Plug boot ends, ditsy cap points, even at the tip of the coil. A coating on the bottom of the disty cap helps seal it too.
Check the coil for cracks as well.
I used to have a bogging/hestitation condition on a wet day and I found that Dielectric grease does wonders.
Old Mar 8, 2009 | 03:20 PM
TMS Bill's Avatar
TMS Bill
I'd use no less than 8m. I always overkill so I never have to worry about it again.
