A slug in rainy weather
Old Mar 9, 2009 | 09:55 PM
wjxavier's Avatar
wjxavier
dont mean to jack your thread or anything, but i've been having the SAME EXACT problem and its been no **** plaguing me forever. it's driving me insane. it's gotten to the point where now, instead of it just doing it in the rain or when its wet out, it does it all the time. and it's idleing bad as well. i just got done replacing the dist. cap, rotor button and wires. none of those made a bit of difference. the only thing i have to go off of is my check engine light comes on after a while and i took it to the mech. to get it read, and it came up code 21 (cyl. 8 low compression?). idk if that would be the problem or not. any other ideas as to what this problem could be?
Old Mar 9, 2009 | 09:57 PM
dodge15004x45.9's Avatar
dodge15004x45.9
yea I see it in the front end now the grille the top part. I'm in a kinda simlar boat go to high school still work 20+ hrs a week and take a class out side of school tuse and thursday night 7-10Pm sp I get home at 11:30 and get up at 6:45.
Old Mar 9, 2009 | 10:40 PM
wjxavier's Avatar
wjxavier
any ideas on what can cause this problem? it's nice (kinda) to know that i'm not the only one with this problem.
Old Mar 9, 2009 | 11:28 PM
TMS Bill's Avatar
TMS Bill
Coil ... wanna see something cool? Wait until after dark, start 'er up with the hood open and mist the motor really good. Watch the light show.
Wait ... mist it first ... then start it ... I've heard it can knock your d1ck in the dirt if it's leaking (electrically) really bad.
JackJ's Avatar
JackJ
I would be willing to bet that you are getting water into the cap and rotor, all it takes is a bit to really make a difference, my JEEP dose this when I am hitting mud holes unless I keep the RPM's up. if you are the type to run mud alot there are ways to water proof your cap and rotor. The shit of it is that the way these motors were desinged it is not practical to check, I would advise that you look up the wayd to water proof it and then see if it continues.
Old Mar 10, 2009 | 06:15 AM
dblj16380's Avatar
dblj16380
Like I said originally, it only does it in the rain and if I pop it in Neutral it revs right up without hesitation. It is only when it is in a drive gear that it does it (and it seems to be at lower speeds too). Could this just be because of the load on the engine? Would moisture in the distributor cap really cause it to bog out in gear and run fine in Neutral or Park?
Old Mar 10, 2009 | 11:07 AM
wjxavier's Avatar
wjxavier
well, the same thing WAS happening to me like i said. i thought it was moisture in the dist cap as well, but it does it now while its dry out. so thats not what the problem is. i replaced the cap, rotor button, and wires. nothing worked.
Old Mar 10, 2009 | 11:39 AM
TMS Bill's Avatar
TMS Bill
Are you thinking "Coil"?
You should ... coil ... coil ... coil ... coil ...
Old Mar 10, 2009 | 01:12 PM
dblj16380's Avatar
dblj16380
So, this may sound dumb, but I thought vehicles either had distributors or coil packs? Aparently not, but anyways, how many does the 360 have?
Old Mar 10, 2009 | 01:43 PM
dblj16380's Avatar
dblj16380
Ahh, I think I figured it out. Does the coil control the spark pulse that goes to the distributor and the distributor cap and rotor control (in a sense) what cylinder gets the spark?
I was looking on AutoZone's site at how to stuff and it said "coil locations" and I got confused and then I realized the diagram they have is for a V10 and is different then the V8.
I have just one coil, right?
