couple issues.....
Old Mar 9, 2009 | 12:03 PM
Linustratus's Avatar
Linustratus
Default couple issues.....
Does anyone know where to get a head liner? or at least know a fix for one, its falling apart. the fabric is coming off, and its driving me nuts. also, i have a sticky window, drivers side, goes down fine, but the last 2 inches up i have to help it! that really sucks. I tried lubricating the slides, no luck. also looking for the window trim, at the bottom of the opening. seems that inside theres some metal and its rusted and bubbled up and now it sticks out..........
Old Mar 9, 2009 | 02:18 PM
Linustratus
bump.
Old Mar 9, 2009 | 03:43 PM
dblj16380's Avatar
dblj16380
As far as the headliner goes, I think they sell like a spray adhesive that you can get for that. You poke a small hole in your headliner (just enough for the straw) and then spray it in there and press the liner back in place. I've never tried it, just heard about it.
When it comes to the window, I would guess it could be a few things. 1) a window motor starting to go bad. 2) your track may be bent or part of the mechanism in the door could be messed up. 3) your rust issue on the door trim could be causing the window to try and grab it on its way up.
I don't know where you could get the window trim. Probably try a junkyard or AutoZone/Murrays or the dealership. I would think it is probably a pretty available part. If there is metal on it though then you will probably have to take your door panel off to remove it.
Good Luck!
