What grade fuel to use?
Old Mar 8, 2009 | 03:38 PM
CoolRide's Avatar
CoolRide
Default What grade fuel to use?
Hello all,
I did a search and
read through the first 5 pages of "what mileage are you getting" but didnt see any with the V10 Magnum?
I just brought home a 2001 SLT Laramie 2500 4x4 with the V10 magnum and auto trans. Short bed and I dont know what the cab is called it has little back doors and a bench seat in back. I am curious as to what mileage I should be able to expect?
Also what grade gas to use does it matter.
No mods that I am aware of.
Thanks Sammy
Old Mar 8, 2009 | 03:52 PM
TMS Bill's Avatar
TMS Bill
You'll find that most people have an opinion on this. I just put the cheapest crap I can find in it and, if it runs fine, keep using it. If it doesn't ping, you do NOT need higher octane. Octane is a NEED thing ... not a WANT thing. Using Super when you don't need it is throwing money away.
edit: Oh ... and it's called a "Quad Cab".
From what I've read here, you'll probably see numbers similar to the 5.9L V8.
Old Mar 8, 2009 | 05:20 PM
CoolRide's Avatar
CoolRide
Quad cab.
Cool Thanks.
I should have just looked up the compression on my motor I guess. I just put the "cheap" stuff in it and it seem to be doing fine. Maybe when the weather gets hot or if I'm pulling a heavy load I may put the 92 in it if it starts pinging.
I have seen everywhere from 8 to 21 mpg on this forum. Guess I'll find out sooner or later.
Thanks again
Sammy
Old Mar 8, 2009 | 06:37 PM
TMS Bill's Avatar
TMS Bill
21 mpg on a 10 banger ... wow ... good luck with that.
Old Mar 8, 2009 | 06:57 PM
helms's Avatar
helms
lol, my truck accually runs worse on higher octane, I run Chevron 87 as much as possible and if i cant get that, then i go with whatever the lowest at Esso is.
Old Mar 8, 2009 | 08:50 PM
PurplDodge's Avatar
PurplDodge
Anybody try that new Shell Nitrogen-enriched gas?
I use Mobil 89.
Old Mar 8, 2009 | 08:57 PM
TMS Bill's Avatar
TMS Bill
What is N supposed to do ... besides take up molecular space? It's inert.
Old Mar 8, 2009 | 09:02 PM
aim4squirrels's Avatar
aim4squirrels
89 is the worst you can use IMO.
It sits in the tanks the longest, and collects water via condensation or straight up leaks in the tanks.
IMO the best place to go is one that does a lot of business and has high turnover of product. Top tier gas is nice too.
Old Mar 8, 2009 | 09:48 PM
madmax0r's Avatar
madmax0r
why would 89 sit in the tanks longest? thats what most cars and trucks use... mid and high is for performance engines
Old Mar 8, 2009 | 10:51 PM
aim4squirrels
no, most use either 87 or 93 (91 in Cali).
