Someone with a camera...Please HELP!
Can someone please take a picture of the throttle valve cable where it connects at the transmission. I think I am missing a piece or its setup wrong or something. This isn't my truck, its a work truck so I'm not too familiar with it. Its a 97 5.9 diesel if that helps any.
thanks
-Kaleb
thanks
-Kaleb
Awesome! that helps a lot. So the cable runs from the front, loops around and then hooks on the post for the throttle valve? Thats the way it looks. Explains why it didn't look right when i put it on.
thanks again for the pics.
I did try the logical thing. Made me wonder why there was so much slack and why that valve was backwards
I thought i might be missing more parts. Turns out I just have it ran wrong. Could you give a brief explanation on adjusting the cable. I am not sure what the lock is and where to pry up and I may have already broken something
Trending Topics
Booya
... quick search revealed this gem: http://www.bionicdodge.com/Download/...Adjustment.pdf
Make sure you have a PDF reader installed ... I use Foxit but most probably use Adobe.
... quick search revealed this gem: http://www.bionicdodge.com/Download/...Adjustment.pdfMake sure you have a PDF reader installed ... I use Foxit but most probably use Adobe.
