Steering Stabilizer
Old Mar 16, 2009 | 11:39 AM
  #21
05DodgeRamHemi's Avatar
05DodgeRamHemi
When you say intrusive, do you mean it looked overbearing looking in the front end? If you're running one stabilizer, then I see no need for me to run two. Do you have any suggestions with which one to go with? Also, do you have any person preferences? I've looked at Monroe, Skyjacker, BDS, Fabtech, Rough Country, etc. There are basically a ton of them.
Old Mar 16, 2009 | 11:48 AM
  #22
Ram2K1's Avatar
Ram2K1
I will say this much...in my case I can tell a difference, but mostly on the highway. A steering stabilizer is basically a shock, and just like a shock, it can wear out. At lower speeds, you won't see much of a difference, since the lower speed creates a higher friction while turning. Just like a bicycle...when you are rolling slowly, you can feel the tire grab more when you try to turn. Then when you are rolling faster, the surface tension between the tire and road is reduced, making the wheel turn easier. A vehicle is the same way. That's why I noticed most of the difference on the highway. It feels stiffer. My dad has an '02 with the stock stabilizer, and from time to time I drive his rig and can tell a definite difference. I think it was worth my $40 investment to have a tighter feel on the highway...just my .02
Old Mar 16, 2009 | 11:58 AM
  #23
Silver_Dodge's Avatar
Silver_Dodge
The dual setups just don't fit good, so the hang down kinda low. That's what I mean. They look cool, but if you actually wheel your truck, I think they hang down too low.
I replace my stabilizer about once a year. They get a lot of use and abuse, and I think it is work the investment. I like the Skyjacker Hydro's and the Rancho.
Old Mar 16, 2009 | 12:01 PM
  #24
Ram2K1's Avatar
Ram2K1
x2...I like my Sj for the price. And you can tell when you lay it next to the stock one, it is a lot beefier.
Old Mar 16, 2009 | 12:04 PM
  #25
05DodgeRamHemi
Cool, thanks guys for your help. I'll probably pick up a new one when I replace the coils up front. Now I'm just hoping my shocks will work with the 3" coils up front lol.
