hop up the 318 or swap
Old Mar 17, 2009 | 09:41 PM
01ramjam's Avatar
01ramjam
sorry for the multiple post i forgot one other thing, how hard is it to switch over to carb instead of fuel injection and would any one suggest it.
Old Mar 17, 2009 | 09:46 PM
MAJohns's Avatar
MAJohns
i don't know the dificulty. i do however know when doing eninge up grades and so forth the more you do the more the computer has to be programed and a computer can only do so much. carbs are easier to work with dodges suck on gas anyway so why not
Old Mar 17, 2009 | 09:58 PM
360dodgeram360's Avatar
360dodgeram360
what is your goal for the 300-350 hp. do you want that much hp to tow or just to go fast? either way i'd recommend just getting a 360 and a nv4500 trans or even nv3500 would be fine if you don't do anything too serious too it. then if u need more tq go for 3:90 gears. Its not gonna be 350 hp but it will be a beast
Old Mar 17, 2009 | 10:19 PM
mr.318's Avatar
mr.318
I'd check www.speedomotive.com they got the best prices on stroker kits for the 318.I built a 330 h.p 318 without strokin it pretty cheap but it's carbed.AS for going carb i don't know bout your year but i did it to a 93 which is t.b.i. do a search on ********* a couple people there have done it I'd stick with the 318 everybody told me to go with a 360 now when i tell em it's a 318 at the track they say noway gotta love it
Old Mar 17, 2009 | 10:41 PM
01ramjam's Avatar
01ramjam
i dont tow with it, its more than less a toy/project what all did you to to get 330 without doing a stroker thanks for all the info. will 3.90s still be drivable on highway
Old Mar 17, 2009 | 11:04 PM
360dodgeram360
i dont know about the nv4500 ratios. but my 318 with the nv3500 and 3:55 turns 2500 @ 85. and i have taken it on 20 hr trips. so yes you will be able to drive it on the highway but it depends how loud the exhaust is. i'd guess w/ 3:90's you'd be lookin at 2800 RPM @ 85. if OD is the same as the nv3500
Old Mar 18, 2009 | 04:06 PM
mr.318's Avatar
mr.318
I had the block bored 40, zerodecked, k.b.167 pistons stockrods and crank,arp bolts Then a set of stockcasting 360 heads with 202-168 vavles,from indyheads,i gasketmatched ported em myself a small 484-474 dualpattern cam , But as isaid it was carbed and these up grades won't work with the compu.fuel inject. ect.And your wanna keep all that,So your gonna need to go a differnt route
Old Mar 18, 2009 | 06:41 PM
01ramjam's Avatar
01ramjam
well the idea of carbing it has almost ran acroos my mind enough to do it. What manifold did you use and what carb,
Old Mar 18, 2009 | 08:08 PM
01ramjam's Avatar
01ramjam
will heads from a 360 bolt up directly to the 318 and are the headers from my 318 gonna bolt up to the 360 heads?
