lift
Old Mar 18, 2009 | 06:04 PM
acsamples79's Avatar
acsamples79
Default lift
im thinking im going to snag one of these kits from summit:
http://store.summitracing.com/partde...130+4294843846+
looks like it would work pretty good, it says 2.5 in the front and 2.5 in the back, and since im not familiar with suspension lifts so much, would that make it level out with 2.5 inches of lift total? or will that litterally just add 2.5 inches to both and the rear still sit higher? thanks
Old Mar 18, 2009 | 07:37 PM
JackJ's Avatar
JackJ
Not a level kit, it would raise the enitre truck 2.5 inches.
Old Mar 18, 2009 | 07:45 PM
acsamples79
yea, i knew it wasnt a leveler, but ive just heard of some lift kits to automatically do an entire lift but it also levels it out, i just didnt know
Old Mar 18, 2009 | 07:52 PM
JackJ's Avatar
JackJ
I read the description for each part and the way it reads is that they both lift either end up 2.5".
Old Mar 18, 2009 | 07:54 PM
Silver_Dodge's Avatar
Silver_Dodge
That's the first lift I ever had on my truck. It was a good spring for the front, but the AAL in the rear made the truck sit higher in the rear then in the front. Escpecially in the beginning when that AAL hadn't sagged down much yet. In fact, when I went to a 3" lift in the front, I kept the same AAL, and then my truck was level. I recommend just getting a 3" lift instead, but it depends on what you are wanting to do with your truck.
Old Mar 18, 2009 | 07:55 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Dude it will lift yr truck go to a junk yard and get 2500 coils and Ill have to find the link for the rear hold on.
EDIT: http://www.jegs.com/i/Skyjacker/825/R222/10002/-1
You do know your going to need new shock as well right?
Old Mar 18, 2009 | 07:58 PM
Silver_Dodge
Its true, 2500 coils from a v10 or a diesel will give you 2" of lift or so on a 1500, but the ride is very stiff. Those Skyjacker coils ride very nice.
Old Mar 18, 2009 | 08:31 PM
dodge15004x45.9
If he want to do it on the cheap thats the way to do it if not sure go spend the 250.00 bucks lol. I would just go with a 3" and get one with the shocks!
Old Mar 18, 2009 | 08:58 PM
LegendKiller89's Avatar
LegendKiller89
I'd buy like a 3'' Rough Country lift with shocks and call it a day.
Old Mar 18, 2009 | 09:35 PM
acsamples79
you guys got any links to any of these ideas, i would just get 2500 coils but last time i went to the pull a part, most of the coils were gone
