Think this package will make 350 hp?
Old Mar 20, 2009 | 09:24 AM
greenmachine's Avatar
greenmachine
I am running 6lbs of boost on an INTERNALLY stock motor w/ a stock transmission and have not a bit of problems. I am also at 95k. I am not running a tuner due to the fact that they advance the timing to far to run a supercharger w/o damaging the engine. Dodge motors are known for having a strong bottom end so I am not worried to much about it. When it does go watch out time for some real power
Old Mar 20, 2009 | 09:37 AM
aim4squirrels's Avatar
aim4squirrels
Greenmachine, Have you dynoed your truck yet?
Just curious as we have the exact same year and probably internals (at least from the factory) and I'm curious as to where you are in terms of HP/TQ. I've been modding recently and wondering how much farther I can push the stock tranny...
Old Mar 20, 2009 | 12:18 PM
xskylinedx's Avatar
xskylinedx
If you only want to spend 3 grand for those numbers your going to need to find a used
supercharger and a new heavy duty trans. I've got a PATC Mega Viper, its been a great
transmission so far.
Just my 2 cents
Old Mar 20, 2009 | 03:59 PM
greenmachine
I am in the process of doing so but am looking into somethings first. Should be within the week. Stock guts, fastman 50mm. dual exhaust, 3.92 limited slip--If you wanted to compare the complete setup
Old Mar 20, 2009 | 04:32 PM
aim4squirrels
I'm pretty sure you're boost with the SC should be well above my HP, just curious as to what you're throwing down.
That SC might benefit from a bigger TB.
Old Mar 20, 2009 | 06:18 PM
tiggamonsta's Avatar
tiggamonsta
Not sure how good they are but you can get a 360HP long block crate motor for $2,600.00. http://www.precisionengine.com/rebui...nes/index.html
Old Mar 20, 2009 | 08:09 PM
dodgeram07's Avatar
dodgeram07
350hp at wheels or crank? i believe about 20% of the hp is lost throw the drive tain so keep that in mind......
nice to see you back greenmachine
Old Mar 20, 2009 | 09:15 PM
aim4squirrels
well, I'm not quite that stock:
Mopar Performance Round A/C
Fastman 50mm Throttle Body
Edelbrock RPM air gap manifold retrofitted for Fuel Injection engine
EngineQuest Iron Ram heads 2.02 intake/1.60 exhaust valves
Harland Sharp 1.7:1 non-adjustable roller rockers
Dual Electric Fans with Flex-a-lite 31165 controller (3750 CFM)
MSD 6A ignition box and Blaster 3 coil
Gibson Performance exhaust headers (shorties)
Sonnax Sure Cure Valve Body valves and springs
Mag-Hytec 727-Double Deep Transmission Pan
Factory Aux Transmission Cooler
Magnaflow 3 si/so high flow catalytic converter
Magnaflow 5X8X24 muffler
4.10 ratio gearing in rear
Detriot Truetrac LSD
SCT tuner -Hemifever tuned
Old Mar 21, 2009 | 12:39 AM
Slomojo's Avatar
Slomojo
bore the cylinders .030 over, get some shiny new kb pistons, some good full sealing rings with reduced friction, cam, and headers. that's all you'll need for a nice boost.
Old Mar 21, 2009 | 01:04 PM
lastrights's Avatar
lastrights
Smile
just wondering how much power your throwing down, i bet its a big diffrence with the gears also??
also have you put the heads on yet, was wondering what kinda gain you see with them ?? the heads go well with the harland sharps ???
