What size tires can I run?
Old Mar 22, 2009 | 04:35 PM
  #31
Ugly1's Avatar
Ugly1
Originally Posted by dodge15004x45.9
Look the only thing I know is when I left the tire shop if felt like it took me long to get up to speed. I'm not sure if it is because of the new tires and wheels what weight more than my old ones. Or if it is the tranny.
That sounds about right to me. In racing circles it is well known that unsprung weight (ie wheels and tires) changes make bigger changes in track performance than the same sprung weight changes. In other words wheels andd tires are one of the primary areas for improvement in racing vehicles.
Old Mar 22, 2009 | 05:09 PM
  #32
Viper37's Avatar
Viper37
Originally Posted by dodgeram07
and the tire size ? were you planing to get lift spindle?? because if you do you will need to get bigger rims to clean the upper c-arm(( but you most likly know that)
Spindle lifts are retarded. I have a 2.5 inch lift up front.
Why would I need larger wheels to clear the upper control arms?
Old Mar 22, 2009 | 05:38 PM
  #33
dodge15004x45.9's Avatar
dodge15004x45.9
One more time?
Old Mar 22, 2009 | 05:39 PM
  #34
pcfixerpro's Avatar
pcfixerpro
With a smaller diameter tire, your gonna lose top end (run higher rpm) but gain low end. Maybe that's what your feeling. Oh wait... the problem is you didn't go BFG
Old Mar 22, 2009 | 05:47 PM
  #35
dodge15004x45.9
F%$@ them dam BFG'S they cost way to much!!!!
Old Mar 22, 2009 | 05:51 PM
  #36
Viper37's Avatar
Viper37
and worth every penny. My Dad crashed my old ranger through a 3 foot concrete drainage channel, up a bank and got airborne before he landed. All that happened at 65 mph and none of the tires were damaged.
BFG FTMFW
Old Mar 22, 2009 | 05:54 PM
  #37
dodge15004x45.9
Sorry If I wanted to spend 800 buck I would buy muds.
Old Mar 22, 2009 | 05:55 PM
  #38
dodgeram07's Avatar
dodgeram07
going to try my best
the lift spindle moves the loction of the hub down moves which moves the truck up.
moving axle of the spindle closer to the move lower c-arm so then because of the ofset of the wheel, then the wheel will hit the upper a-arm
hope this make sense, if not go look at the space bewteen the upper c-arm and the inside of the rim.((( maybe that 2000-2001 have more room because they are diff)
hope i help. if not let me know
Old Mar 22, 2009 | 06:06 PM
  #39
Ugly1's Avatar
Ugly1
One more time?
I guess it is a bit harder to explain why it's true than I thought, but the concept is simple. All else being equal...remove a pound from your wheels and you will improve your track times more than removing a pound from say your interior.
I think it may be harder to picture this when we are talking about 6000 lb trucks that will never see an autocross track or the like but it is completely obvious to anyone who's compared the difference on a motorcycle or a suspended mt bike for example.
Back when I was into mt biking perhaps the best mod I ever spent money on was a light weight back wheel. After the mod, suddenly it felt as though my bonds were lifted and I could ride much faster, farther, better. It was not at all subtle either.
This is an often talked about concept in racing circles. Check out corner carvers suspension forum for many many discussions about unsprung vs sprung weight.
Old Mar 22, 2009 | 06:09 PM
  #40
dodge15004x45.9
I think I might get it.
