What size tires can I run?
going to try my best
the lift spindle moves the loction of the hub down moves which moves the truck up.
moving axle of the spindle closer to the move lower c-arm so then because of the ofset of the wheel, then the wheel will hit the upper a-arm
hope this make sense, if not go look at the space bewteen the upper c-arm and the inside of the rim.((( maybe that 2000-2001 have more room because they are diff)
hope i help. if not let me know
I don't have a spindle lift.
Bleh. I dodn't know why I'm making it so hard. I finally thought of a good analogy.
Which would you rather try to move by kicking it a volleyball or a solid iron ball the size of a volleyball?
Same with your truck it can turn a lighter wheel easier than a heavy one.
Sorry about the confusing previous attempts. over and out.
i understand that you don't have a spindle lift....
i just remenber that when you put in your limiting sraps( because of the spacer and the bump stop problem) you said something like you thought about getting lift spindles...... so i thought if you were getting new tires that maybe to think ahead about the spindle so you don't buy new 16in tires then a month later you want lift spindles and have to buy bigger rims and your new tires will not fit....
thats all, sorry for the miss conution
and my spelling sucks,maybe i need to put that back in "my" sig
dodgeram5.9
dodgeram5.9
I'll say one thing, you got imagination, you go girl!!!
Sammy
How insightful...
You know I peed a little when I thought of it, but honestly, whats her name.... (viper37) needs love too.. who am I to decide?
