Engine Coolant Temperature Sensor
Old Mar 28, 2009 | 11:54 AM
ophidia's Avatar
ophidia
I put a dab of RTV on the threads on mine. No leaks thus far.
Old Mar 28, 2009 | 12:14 PM
dakotas ram's Avatar
dakotas ram
why would the teflon hurt?
Old Mar 28, 2009 | 12:33 PM
ophidia's Avatar
ophidia
I'm pretty sure that's what's recommended in the Haynes manual I have-- Teflon tape. I can't think of a reason why it would hurt. For all intents and purposes the sensor is just a solid chunk of brass.
Old Mar 29, 2009 | 11:39 PM
BigDubDiesel's Avatar
BigDubDiesel
How about medium locktite?
Old Jan 30, 2013 | 01:33 AM
cruisinsolo's Avatar
cruisinsolo
i have a 97 w/ a5.9 . it has both sensors but cant find the location of the ect sensor. nothing to the right of the t- stat housing. just a 2 wire with a sensor in it and no place for it to screw into. any advise or pictures would be helpful.
Old Jan 30, 2013 | 09:20 AM
On mine, the sensor for the gauge (1 wire) is on the passenger side of the thermostat housing, and the sensor for the PCM, (2 wire) is on the drivers side. I wonder if your manifold got changed out at some point?
Old Feb 1, 2013 | 12:53 AM
cruisinsolo
I was thinking the same thing, manifold change. Will look alittle closer to see if there is nt a threaded plug. Thanks for the info
Old Feb 1, 2013 | 07:39 AM
97tn4x4's Avatar
97tn4x4
Every set of gauges I've ever installed said not to use Teflon on the threads as the sensor grounds to the intake and the tape can actually cause a false reading.
Old Oct 27, 2017 | 04:21 AM
Ernie Garcis's Avatar
Ernie Garcis
Default Coolant temp and switch locations and problem
My 92 dakota 3.9L had trouble from the reservoir bubbling up and spewing it out. I assumed thermostat and went with it. Bought a new thermo housing wit gasket permatex and a coolant temp switch wich i heard sends the readings to the gauge. Before all this my gauge was reading hot. So i added those items on and good no leaks but the coolant switch worked for about 10 min and just stopped so now it reads cold. Should i also change the sensor? Btw the thermostat i put in was good as i boiled it and took it out several times and dropped it back in. Also viewing from front of engine, i have a sensor or shall i say sender wich was replaced...on the left side of thermo housing, then i have another sensor on the rite wich i think is sensor. Am i correct on wich sensors are to the sides of the thermo housing?
Old Oct 27, 2017 | 11:59 AM
You want to be in the first-gen Dakota section.
