Engine Coolant Temperature Sensor
Old Nov 15, 2017 | 01:00 AM
  #21
Ernie Garcis's Avatar
Ernie Garcis
Default 1992 dakota 3.9 stalling in drive and reverse
So i recently just changed my engine coolant temperature sensor and thatd when the engine light came on and i got the codes 22.37.45. And ever since temp sensor its causimg the car to die and give those codes. Everything was prrtty ok b4 the new sensor other than it going out which had me replace it. Any ides im not tryna spend so muvh money thanks peepz
Old Nov 15, 2017 | 09:35 AM
  #22
You really want to be in the first gen Dakota section.
Old Apr 20, 2022 | 05:53 PM
  #23
Chetti2's Avatar
Chetti2
Default Ect sensor
Originally Posted by BigDubDiesel
I need to change my engine coolant temperature sensor because my check engine light is on and is throwing code P0117-ENGINE COOLANT TEMPERATURE SENSOR LOW, however I cannot seem to find it. Has anyone changed one before and knows where it is located, i'm pretty sure it's somewhere near the alternator?
Dodge ram 1500, 5.9.
You're going to find it by where the thermostat housing is in front of the engine going to see the radiator hose come out it's that little piece right in there and
Old Apr 21, 2022 | 09:33 AM
  #24
5 year old thread?
