wheel bearings
Old May 11, 2009 | 03:44 AM
dakotas ram's Avatar
dakotas ram
alright, i got the stuff to do this tomorrow(today )......haynes manual really sucks, do i have to torque the outer bolt to a certain spec?
Old May 11, 2009 | 09:34 AM
Sheriff420's Avatar
Sheriff420
Default 2001 service manual
HUB / BEARING
REMOVAL
(1) Raise and support the vehicle.
(2) Remove the wheel and tire assembly.
(3) Remove the caliper adapter bolts from the
steering knuckle and remove caliper adapter assembly
(Refer to 5 - BRAKES/HYDRAULIC/MECHANICAL/
DISC BRAKE CALIPERS - REMOVAL).
NOTE: Do not allow brake hose to support caliper
adapter assembly.
(4) Remove the rotor from the hub/bearing wheel
studs.
(5) Remove the hub/bearing nut (Fig. 3) and slide
the hub/bearing off the spindle.
CAUTION: The hub/bearing nut can not be re-used.
INSTALLATION
(1) On models with all-wheel antilock system
(ABS), check condition of tone wheel on hub/bearing.
If teeth on wheel are damaged, hub/bearing assembly
will have to be replaced (tone wheel is not serviced
separately).
(2) Slide the hub/bearing onto the spindle.
(3) Install the
new hub/bearing nut and tighten
to:
²
LD 1500: 251N·m (185 ft. lbs.)
²
HD 2500/3500: 380 N·m (280 ft lbs.)
(4) Install the rotor onto hub/bearing wheel studs.
(5) Install the caliper adapter assembly (Refer to 5
- BRAKES/HYDRAULIC/MECHANICAL/DISC
BRAKE CALIPERS - INSTALLATION), and tighten
adapter bolts to:
²
LD 1500: 176 N·m (130 ft lbs.)
²
HD 2500/3500: 285 N·m (210 ft lbs.)
(6) Install the wheel and tire assembly and lower
the vehicle, (Refer to 22 - TIRES/WHEELS/WHEELS
- STANDARD PROCEDURE).
(7) Apply brakes several times to seat brake shoes.
Be sure to obtain firm pedal before moving vehicle.
Old May 11, 2009 | 10:05 AM
dakotas ram
thanks
Old May 11, 2009 | 02:52 PM
dakotas ram
well. that was fun....i got the drivers side done, couldnt get to the outer race, so i just left it in there, the inner was pretty bad lookin, while putting the new on in, i was using the old to help knock it in and it got stuck so i got some vise grips and was trying to pry it out and SMACK!!! it let loose and the back of the pliers busted my lip open pretty bad, i ended passing out once i got inside and went to the hospital....very lovely
Old May 11, 2009 | 02:56 PM
dakotas ram
why do i need a new nut? i reused my old one then an impact.....
Old May 11, 2009 | 06:55 PM
dhvaughan's Avatar
dhvaughan
are you serious ?
on the nut, hang on. if you've got the unitized bearing that's around $180 each and bolts into the back of the knuckle, then the outer nut torques at 185 pounds, and you're supposed to use a new nut, (i didn't).
if you've got simple, conventional, inner and outer tapered bearings that cost about $10 each, then the nut is only finger tight, and you can reuse it, and you don't use an impact wrench.
Old May 11, 2009 | 11:09 PM
dakotas ram
yep, dead serious.....it split my lip open inside and out and my gum and chipped my tooth.....there's blood all over the driveway......
yeah, ive got the simple bearings......so i shouldnt have torqued them?....should i back that nut back off? ive already drove bout 50 miles on it
Old May 12, 2009 | 01:47 AM
Sheriff420's Avatar
Sheriff420
don't ya just hate that feeling when you get hurt and realize that its really bad and get the cold sweats and feel like you're gonna pass out? a friend of mine almost broke my finger a couple weeks ago and i got it then so i feel for ya.
my last post is out of the 2001 ram service manual, but it does seem a little off to me. when i did my camaro bearings (tapered) i had to use a new seal but not a new king nut. and i tightened them down to something like 75ft lbs, spun the rotor to seat the bearings, tightened them again then backed it off 1/4 turn and put the cotter pin in and was done.
Old May 12, 2009 | 02:09 AM
dakotas ram
i dont know why i passed out......i was fine, came in and me and my g/f were lookin at it in the mirror, no biggie, then walk into the living room and bam....got to feelin terrible so i sat down and she said i passed out and was shakin...no joke about the blood, as soon as i did it i could just feel it start gushing and drippin everywhere.......do yall think i should back the nut off? while jacked up, it has some resistance...... dont know about now after driving it tho
Old May 12, 2009 | 07:45 AM
Sheriff420's Avatar
Sheriff420
the haynes manual says tighten to 12 ft lbs, spin the rotor to seat the bearings, back off 1/4 turn, then tighten hand tight and put the cotter pin in and you're done. now that i read that i remember on my camaro it was no more than 12 ft lbs not 75. so yeah, back it off and don't drive it till you do. hopefully the newly packed bearings didn't get messed up in that 50 miles.
thats the second time i've seen conflicting info in that service manual. i think on my post from it that it was supposed to say inch pounds and not foot pounds.
