Old Aug 5, 2015, 01:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
Brake rotors and calipers
Old Mar 31, 2009 | 01:41 PM
UltraMag50's Avatar
UltraMag50
Unhappy Brake rotors and calipers
So i've been needing brakes for a while now, but with no job its been hard coming up with money. On my way home today my brake pedal went to the floor. upon futher inspection, the back side of the driver side rotor is completely worn down. Im assuming i fcuked up the caliper, because it's leaking fluid =[ so i called up my local dodge dealership to see how much calipers and rotors cost. I was told $113/ea for calipers, and $153/ea for rotors . Auto Zone stocks Duralast Gold rotors for $56/ea, and Morse loaded caliper pairs for $106. However, going through the dealership i may be able to make payments, since my mom works there and can have them put on her tab. What does DF think? any other suggestions? this could be a good time to upgrade to 2-piston calipers, but i need work on this ASAP. Thanks
Old Mar 31, 2009 | 01:54 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
http://www.rockauto.com - Buy rotors, pads, and a caliper rebuild kit.
After that, learn to keep your vehicle properly maintained at all times.
Old Mar 31, 2009 | 01:56 PM
UltraMag50's Avatar
UltraMag50
Thanks, i never figured out what i needed to do to it...
any other HELPFUL suggestions?
Old Mar 31, 2009 | 02:06 PM
steve05ram360's Avatar
steve05ram360
if money is tight... wrecking yard. should be able to get you set back up pretty cheep. also, you may also checkout craigslist.org for anyone parting out a ram. you may be able to find your parts that way.
Old Mar 31, 2009 | 02:16 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
While you're at it, replace & regrease the front wheel bearings.
Old Mar 31, 2009 | 02:19 PM
UltraMag50's Avatar
UltraMag50
THANK you VWanddodge. wouldnt have thought of that, seriously. Any recommended brands for bearings?
Old Mar 31, 2009 | 02:25 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Go to the Rock Auto Website. Everything you need is there.
Old Mar 31, 2009 | 03:03 PM
dodgeram07's Avatar
dodgeram07
4x4 or 2wd?
because i need a rotor and looked there 56.99 at advance auto in my town.
http://shop.advanceautoparts.com/web...MAMS__rotor___
autozone is cheaper at 45.99 http://www.autozone.com/autozone/cat...estions=%5B%5D
+1 on rock auto sumtime if thay have the same part as adavance, adavance will macth there price......
Old Mar 31, 2009 | 04:17 PM
UltraMag50's Avatar
UltraMag50
sorry, its 4x4, and NAPA in my hometown quoted me $217 for rotors, calipers, and pads, with a $20 core charge on each caliper. probably gonna go that route... thanks for the help, im checking out rock auto right now...
btw, is the brake dust shield necessary? i noticed its practically rusted away. should i leave it off or replace it?
Old Mar 31, 2009 | 05:36 PM
PurplDodge's Avatar
PurplDodge
Raybestos brakes are the best. Get them at Rock Auto. I just got ceramic brake pads and bolts and bushings for under $70.
