why adjust transmission bands?
Went to tranny shop the other day to ask about the band adjustment. Now my truck is a 2001 with one twenty four thousand miles and bands were never adjusted before as far as I know. He told me to loosen the lock nut, turn the adjuster 1 turn clockwise (to tighten) and tighten the lock nut. He said that is what he would do if I had him do it. He said the procedure where you tighten to 72 in lbs and back off 2 turns is for new or newer transmissions. What do you guys think?
UnReg's right, guy who told you that is crazy.
Which band are you adjusting?
Edit: For some reason I thought this was the guy on the bottom of the last page..... Oops...
