help asap headlight issue
Old Apr 1, 2009 | 07:30 PM
white_lightning318's Avatar
white_lightning318
Default help asap headlight issue
hey guys,
i just pulled into my buddys placxe and my lights wont shut off, the high beams are stuck on ....funny part is i didnt have my lights on at all today but they are stuck on. im assuming a loose wire or ground but this bein my first dodge im not sure where to look...any ideas would be great cuz my battery is dying as we speak!!!!! thanks guys
Old Apr 1, 2009 | 07:33 PM
dhvaughan's Avatar
dhvaughan
pull the fuse or disconnect the battery.
check the headlight on/off switch. they are prone to go bad.
you can get a replacement at autozone, advance, etc.
Old Apr 2, 2009 | 02:40 PM
white_lightning318
well i pulled the fuse out from under the hood to keep them off when needed. I will try the headlight switch but its the high beams that are on ,and even with the lights actually turned on by the switch, you cannot fluctuate between high and low beam.my buddy was wondering about a loose ground. i work at carquest so either way parts i wont have a problem buying but it is embarassing to have to pop the hood everytime you wanna go somewhere at night
Old Apr 2, 2009 | 02:44 PM
xskylinedx's Avatar
xskylinedx
Could that be a bad relay?
Old Apr 2, 2009 | 03:18 PM
white_lightning318
Well im sure you guys will know better but i have been told that there is no relay on these trucks just the fuse under the hood. I tried changing that fuse as well and it didnt change a thing.
Old Apr 2, 2009 | 03:52 PM
xskylinedx's Avatar
xskylinedx
Thanks for the vote of confidence but I honestly don't know
Just thought I would throw it out there.
Old Apr 2, 2009 | 10:36 PM
dhvaughan's Avatar
dhvaughan
no relay.
i doubt that its a loose ground.
you've got the headlight sw performing the on/off function.
then you've got the multifunction sw on the column doing the hi/low.
did both of your problems start at the same time, or has the hi/low problem always been there ?
headlight sw is easy to replace.
multifunction takes a couple of hours and you'll need a set of security torx after you finally get the damn covers off the column.
Old Apr 3, 2009 | 11:52 AM
white_lightning318
New update....turns out the highbeams will switch off and on but the highbeam indicator light stays on and im still pullin the fuse everytime i go somewhere.So its safe to say buy a new switch and try that?
