Took my truck to a local garage to get an estimate on a custom exhaust. When the guy put it up on the rack, I started looking around underneath just to check things out when I noticed (What I think.) is my pinion seal coming from the transfer case is leaking. I havn't noticed anything in my garage or where I park at work but, I could see where it was spinning the fluid underneath my truck. The mechanic said that it was a pretty easy fix. Has anyone done this? If so, how difficult? I am somewhat mechanicallly inclined and would like to fix this myself if at all possible. Any info would be great![sm=helpout.gif]
it's a pretty easy fix just remover the drive shaft ,pry out the old seal an install the new one.I just changed mine two weeks ago when I changed the torque converter.
I am pretty sure its the seal. It is where the drive shaft goes into the trasfer case. You can actually see part of the seal hanging down and the fluid is all around it. 2001ramsport, is it hard to remove your driveshaft? Dont' you unbolt it at the unversal joimt and just slide the drive shaft out? That is one thing I have never done. Just not to sure about it.
Thanks for all the help. I talked to the guy that is going to do my exgaust and he said he would do it for $20.00 while it was up on the rack. So that sounds pretty good to me. I might watch him do it so I will know for sure.[sm=smiley20.gif]
