Installed a 195 thermostat, need help!!!
Old Apr 3, 2009 | 04:21 PM
charlie1935's Avatar
charlie1935
I've had one fail-safe and sure enough it failed. It did fail safe (open) though.
Old Apr 3, 2009 | 04:33 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by J415
Good one. Nice way to come back on me with that word. In all seriousness, why use stant superstat? I use Fail-Safe thermostats only because if you start to over heat, it will trigger the stat to lock open so you won't stuck on the side of the road. People don't plan on overheating their truck or car. From my experiance, it almost ALWAYS happens when you LEAST expect it...or for that matter when you don't want it to.
thanks again everyone...
All thermostats are supposed to fail open.
Old Apr 3, 2009 | 05:08 PM
hutch1973's Avatar
hutch1973
To agree with the previous posters, seems like a bad stat, unless of course you accidentally got it turned around when you installed it....
If that's the case, still say it was a bad stat...lol
Old Apr 3, 2009 | 05:45 PM
wjxavier's Avatar
wjxavier
i dont understand how you could get it turned the wrong way...if you took it out, i mean, thats common sense. i had the same problem for a while...it was doing that, i changed my thermostat and it didnt do it so drastically but still did it a little (like what you're talking about) so i just let it ride for a little bit...it eventually worked itself out. idk how though.
Old Apr 3, 2009 | 05:59 PM
TMS Bill's Avatar
TMS Bill
Am I missing something? The truck's not overheating ... the temp on the gauge is floating a bit but it's not out of line. Why would this be a bad stat?
Old Apr 3, 2009 | 07:10 PM
Laramie1997's Avatar
Laramie1997
Could be lack of a breather hole in the stat causing this to happen.
It could also be his fan clutch too if its starting to warm up in his part of the country.
Old Apr 3, 2009 | 07:37 PM
aim4squirrels's Avatar
aim4squirrels
Sounds like it's upside down to me too. Did you put it in pointy side up or butt end up?
Old Apr 3, 2009 | 08:09 PM
J415's Avatar
J415
I know enough to know that I installed it the correct way. Hey VW&DODGE, my sisters 03 diamante's stat failed. it stuck shut. she had to have it towed home, 100 miles away which cost her $400. The main thing that concerns me is that it warms up to temp a little too fast. It just bugs me, is all. That never happened with any of my other stats I installed. I'll see how it goes.
Old Apr 3, 2009 | 10:11 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I understand what you're saying, OK? My dad is a retired automotive engineer (back in 1985) and in the 1990's he commented to me that he'd been hearing more and more of t-stats failing closed. He said that was absolutely unheard of up through his retirement and he wondered if QA was lacking.
My point is that all t-stats are supposed to fail OPEN. Period, end of story.
Old Apr 3, 2009 | 10:20 PM
BlueBeast2's Avatar
BlueBeast2
I was always told to put a Tylenol in the tstat so it would be open and by the time the pill melted the air should be bled out. Think I've only tried it once though. Thats another part I rarely change
