Brake guru's, need some help
Old Apr 3, 2009 | 02:50 PM
Silver_Dodge's Avatar
Silver_Dodge
Default Brake guru's, need some help
I'm going to be replacing my brake lines with these kevlar braided stainless steel brake hoses from EGR Performance Brakes. I'm also going to replace my pre-bent rear hard line tube while i'm at it.
http://www.egrbrakes.com/brakelinekit.htm
http://www.egrbrakes.com/pdf/PreBent...placements.pdf
When you go to order, they sell different kits depending on if you have 2 wheel or 4 wheel anit-lock brake system. I checked the Chrysler service manual, and our trucks did indeed come with either a 2 wheel system, called RWAL in the service manual (Rear Wheel Anti Lock), or a 4 wheel system called ABS in the service manual (All-wheel Anti-lock Brake system).
My question is, how do I know which I have?
Old Apr 3, 2009 | 02:52 PM
Silver_Dodge
My build sheet has this on it:
BGJS - Pwr Disc/Drum Rr Anti-Lock Brakes
I think this means I have RWAL.
Old Apr 3, 2009 | 03:11 PM
PurplDodge's Avatar
PurplDodge
I bought the Russel Stainless Steel Braided lines. I'm going to install them whenever I replace my track bar and front brakes.
Old Apr 3, 2009 | 03:57 PM
UltraMag50's Avatar
UltraMag50
If you don't have ABS, the you WILL have RWAL. Its either you have one or the other. however, idk where to look to see if you have ABS, since I have RWAL. You might check the brake pedal itself, usually it says "4-wheel ABS" or something similar on the rubber pedal cover.
Old Apr 3, 2009 | 04:06 PM
charlie1935's Avatar
charlie1935
If you have 4 wheel anti-lock there will a wire to a sensor at each front wheel.
Old Apr 3, 2009 | 04:21 PM
Laramie1997's Avatar
Laramie1997
There should be an extra set of wiring coming off of the pcm if you have 4 wheel ABS. More than likely its rear wheel abs.
All of these trucks came standard with rear wheel ABS as well.
Old Apr 3, 2009 | 08:11 PM
J415's Avatar
J415
check the relays. If you have a relay where the ABS relay goes, then you have ABS 4W
Old Apr 3, 2009 | 09:33 PM
dsertdog56's Avatar
dsertdog56
+1 on the wires coming from the hubs, the extra relay, and PCM wiring. My guess is you'll have rear wheel only.
