spark plug problem
Old Apr 4, 2009 | 05:58 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You don't have to pull the head, and as far as making some kind of adapter for a vacuum cleaner, all I can say is use your imagination. I also assume you know to pull the heat tube that surrounds the plug.
Old Apr 5, 2009 | 08:31 AM
97tn4x4's Avatar
97tn4x4
no i was actually gonna ask how to pull that. so i just chase the threads with the same size tap put the heli coil in suck out shavings and put the plug back in right. also can i take the plug back out or should i go ahead and replace the plugs?
Old Apr 5, 2009 | 08:35 AM
97tn4x4's Avatar
97tn4x4
also if i need to do the plugs any suggestions as far as brand and type.
Old Apr 5, 2009 | 09:14 AM
wjxavier's Avatar
wjxavier
i would think about 85%+ people would agree champion plugs.
Old Apr 5, 2009 | 11:23 AM
TMS Bill's Avatar
TMS Bill
Champion Truck or Champion Copper.
Old Apr 5, 2009 | 12:23 PM
zman17's Avatar
zman17
+2, Champions.
Old Apr 6, 2009 | 02:53 AM
J415's Avatar
J415
Hmmm...something that sucks? Maybe a shop vac and a pencil magnet...
Old Apr 6, 2009 | 08:06 AM
97tn4x4's Avatar
97tn4x4
how do i get the heat shield from around the plug?
Old Apr 6, 2009 | 11:05 AM
TMS Bill's Avatar
TMS Bill
Vise Grips and something to tap with ... um ... a 2 lb. maul comes to mind.
Seriously ... they're pressed in ... they should yank out. A few of mine fell out while I was changing plugs.
If yours are tighter, ye olde standbys ... heat, deadblow hammer, penetrating oil.
Old Apr 6, 2009 | 11:31 AM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Just use a heater hose clamp. Tighten it around the shield and it will come right out. Don't need to maul anything.
With the heli-coil, you are going to have to drill out the stripped spark plug hole to the next size and retap it for the coil. You could probably do it with the head on, but I would advise against it. You will generate a lot of chips and metal shavings and you won't be able to get all of them out with the head on.
