Hey all, just wanted to verify for someone that the 5.2 intake manifolds are the same as the 5.9 intakes from 94-01. the only difference is the EGR valve. some have them some don't. Am I right? I'm 99.9% sure I am. thanks for those who chime in.
they also switched from 2 cooling sensors/senders to 1 somewhere in the middle around 96-97
are you sure, because I have a '97 non-egr and I have 2 cooling sensors/sender. I know because I broke both when I pulled out the thermostat housing (Stupid F#$@ING tab on stat housing!!!)
